2007 H3 Hazard Lights "ON" without button pushed
Old Apr 26, 2023 | 06:01 AM
Disel's Avatar
Originally Posted by Nikal
The Sun roof seems to be the biggest failure and causes the most issues & damage on the H3. Huge fail on GM’s part.
5 years on H3. I clean drains twice a year. Everything is fine!
Old Apr 26, 2023 | 06:46 PM
dwimpari's Avatar
Turns out my drain tube wasn't clogged, but just dangling open behind the glovebox.
I pulled the panel and found the BCM and all connectors soaked... Took out the BCM and dried it out. Took a hair dryer to the wire connections too.
Put it back in and the only light that comes on when I turn the key is the check engine light.
Car won't turn even attempt to crank (with a full battery) and the key is stuck in the ignition again.
Old Apr 26, 2023 | 07:04 PM
dwimpari's Avatar
Resting battery voltage is at 12.9V
Old Apr 26, 2023 | 07:16 PM
Did you disconnect battery before BCM disconnect? If not, disconnect battery, key in ignition, all doors closed, for at least 30minutes.
Old Apr 26, 2023 | 07:20 PM
dwimpari's Avatar
Yep, disconnected the battery before removing the BCM. Then left the battery disconnected overnight with the key in ignition and all doors closed.
Old Apr 26, 2023 | 07:25 PM
Signal loss from the BCM connector/contacts.
Old Apr 27, 2023 | 09:34 AM
Kind of like drying out a cell phone that went through the wash. A few time they might work normally after that, but not likely.
jay77
Jun 27, 2022 06:13 PM
Amy_green75@yahoo.com
Aug 31, 2020 09:05 AM
OCFDfyrfytr
May 28, 2016 01:57 PM
Derian06
Apr 8, 2014 12:00 AM
Mcasner
Aug 18, 2012 08:19 AM
