2006 H3 towing
Old Jul 10, 2020 | 01:31 PM
Gdraft's Avatar
Default 2006 H3 towing
I have a 2006 and was curious as to how much it could tow? Looking to be able to tow a boat. THX in advance
Old Jul 10, 2020 | 01:36 PM
Maximum towing capacities: 3,000 lb (1,361 kg) for the straight-5 with manual transmission, 4,500 lb (2,041 kg) for the straight-5 with automatic transmission, and 6,000 lb (2,722 kg) for the V8 with automatic transmission.
Old Jul 13, 2020 | 07:10 AM
Buy an owners manual and read section 4-57 through 4-66.
Many factors go into towing, the tow rating is only part of the actual weight you can safely tow. The GCWR (Gross Combination Weight Rating) is the most important information you need. It's on the door sticker with the tire inflation information.
Tongue weight can cause the vehicle to exceed the GVWR (Gross Vehicle Weight Rating) or the RGAWR (Rear Gross Axle Weight Rating) too.
People will come in and say "oh I've towed 10,000lbs 2,000 miles with no issues" or " I'm just going 5 miles to the lake, it's OK".
Just because someone may have done it does not make it safe, legal nor will your insurance company cover any damages or medical if you towed over the limit of your vehicle.
Download your Owners Manual from GM.
https://my.gmc.com/content/dam/gmown..._h3_owners.pdf
Old Jul 16, 2020 | 03:54 PM
Gdraft's Avatar
Thanks. The boat I want to tow weighs 3300 and the tongue weight is 375. After reading the specs, it appears mu Hummer will tow it with no problem
Old Jul 16, 2020 | 07:50 PM
wpage's Avatar
You should have no problems...
Go slow on the gas and the brake.
Old Jul 17, 2020 | 08:45 AM
How much does the trailer weigh? Add in the spare tire on the trailer, any stuff you keep in the boat, and fuel. Specs for boats are usually dry weight. Then put 4 people in the truck with all your gear......
You should still be able to tow it, the description of "no problem" is a different matter. Hook that up and see how hard that 3.5L has WORK to do it and get ready for the old tail wagging the dog feeling. My 07 with every performance mod you can think really had to strain. The H3 short wheelbase is not a towing plus.
HogTech
Mar 14, 2020 03:08 PM
rob85635
Mar 17, 2008 11:52 AM
countrysquireboy
Oct 25, 2007 12:57 PM
rob85635
Jul 19, 2007 08:55 PM
dave85c4
Mar 15, 2006 05:24 PM
