09 H3 wobbly wheel
Old Dec 11, 2019 | 07:57 PM
Bricks's Avatar
Default No alignment
Could be one of the following (no specific order & there could be more):
Brake/ABS activity on left side
Brake locking up or dragging
Hub on left side is still bad
Alignment done incorrectly
Tires are in need of balancing & or rotation
Brake line on left side pinched, swollen or mushy
Just some thoughts...
turns out pep boys never did an alignment. Got an alignment and it still pulls a little to the left, but only sometimes. Maybe it needs new tie rods? The steering feels kinda loose for me, like there's too much play in the steering wheel but I'm not used to driving trucks/SUVs so maybe I'm just paranoid.
Old Dec 11, 2019 | 08:12 PM
you need to have your steering components checked properly idk if "pep boys" is qualified. the steering should be tight and not wander or need constant corrections when driving.
Old Dec 11, 2019 | 08:26 PM
Bricks's Avatar
10-4 thanks. It's definitely not "tight". The mechanic today (proper mechanic shop) said everything looked good but I'll get a second opinion.
Old Dec 11, 2019 | 10:07 PM
Originally Posted by Bricks
got an alignment and it still pulls to the left. On the highway it feels like the left front wheel is wobbly.
Any ideas what it could be?
Initially a "pull" and "wobbly", and now "loose". Just make sure you have good insurance, before you drive!
Old Dec 13, 2019 | 04:52 AM
LatvjuAvs's Avatar
Check if steering shaft u-joints are fine(upper-lower), multiple mechanics missed that on my car.
Also, there is a gear inside your steering rack/pinion that your shaft is driving, it wears out with time, there is adjuster bolt something on top of it that will push those gears closer.
Will make steering harder but on worn gears will fix(temp) play/wobble/catch car on the road mini game.
Or shell out papers for proper mechanics, not cheaper = better mindset.
Old Dec 13, 2019 | 12:41 PM
Bricks's Avatar
UPDATE: Pulling into a parking spot today. Started shuddring. Heard a loud Ping! when I shifted into park. Any ideas?
Old Dec 13, 2019 | 05:16 PM
Check the joints on the front propeller.
CodyB
Aug 7, 2011 11:45 AM
zefrum
May 3, 2011 03:57 PM
chrisstaton
Dec 27, 2010 07:08 PM
jrbnc
Nov 27, 2007 12:38 PM
