08 H3 getting multiple warning lights, any ideas?
Old Nov 22, 2021 | 08:48 PM
CooperWalker's Avatar
Default 08 H3 getting multiple warning lights, any ideas?
My 08 H3 recently started getting a fluid warning and illuminating the red brake light, if I tapped the brake peddle it would go out and not return. Yes, it has brake fluid, it is filled and the level does not decrease. After doing this intermittently for the past month or so the traction control warning and yellow indicator has joined in the fun and a service warning comes along with it. The brakes work absolutely fine, there is no brake issue, there is no traction issue, any ideas how to correct these issues since I have an inspection due and no idea where to begin, thanks in advance.
Old Nov 23, 2021 | 12:19 AM
Happy Hummer's Avatar
So it is an electronic issue?
If I'm reading correctly?
Old Nov 23, 2021 | 09:46 AM
Scan with a real scanner and post the code(s), you have might a poor connection to the ABS module. Use a scanner, not an OBDII reader.
odieholtz
Apr 27, 2021 10:47 AM
Chillywilly
Jul 23, 2019 11:41 AM
tqu9047
Apr 22, 2017 04:03 AM
sns
Jun 1, 2010 07:42 AM
harriman7021
24
Dec 16, 2008 07:24 PM
