Brake job nightmare
Old Jul 18, 2019 | 06:56 PM
Chillywilly's Avatar
Default Brake job nightmare
I have an 07 H3 with 191,000 mi. Just replaced both front brake hoses, calipers, rotors and pads. Getting all kinds msgs on the dash. brake fluid, stability control, traction control. Both the traction control and brake lights are on in the dash. The brake fluid level is good. I tried to reset the computer by disconnecting the battery (for 30 sec). I have a OBD reader and tried resetting any codes...there are none. Does anyone have any suggestions? Thanks in advance.
Old Jul 18, 2019 | 07:26 PM
Read up on the proper way to bleed the ABS system. Also check the ABS sensors, connections and wires.
Old Jul 18, 2019 | 08:57 PM
You left air in the hydraulic system.
Ok, thank you. I will give it a shot.
Old Jul 18, 2019 | 09:02 PM
Hummerz, the brakes do seem to be too soft. With new brakes, they should be tight. Thanks
Old Jul 19, 2019 | 05:10 PM
That was it boys. Air in the lines. The RF bleeder was sucking air in through it's own threads. We got done. All dash lights off...
Thanks Again!
Old Jul 21, 2019 | 09:26 AM
PS. Disconnecting the Battery doesn't reset anything. The H3 flash based memory stores the last 300 ignition cycles regardless of power or no power.
Glad you were able to get the air out.
Old Jul 21, 2019 | 01:23 PM
Thanks Again!
Nice work.
The best part of diy, there was a problem, and you received an error message, and in your case, traction control. No codes=No electronic failure.
Traction control found a variance in 1 of 4 wheels when you were braking on your test drive.
You found it and corrected it, and saved yourself a lot of money. No lights, stiff pedal, you can drive safely now.
Old Jul 23, 2019 | 11:41 AM
Thanks Again!
Excellent!
We like it when owners come back and let the rest of us know it worked or not.
Hhummer
Mar 13, 2019 09:38 AM
tqu9047
Apr 22, 2017 04:03 AM
bryanw
Apr 4, 2015 03:54 PM
bryanw
Apr 3, 2015 07:48 PM
martymrgrin
Feb 21, 2013 06:43 PM
