07 H3 at a loss money pit HELP plz
Old Jul 19, 2025 | 10:08 PM
BLK07H-3's Avatar
Default 07 H3 at a loss money pit HELP plz
Okay guys I have a 07 h3 3.7 the timing Chain went and I decided to replace engine Now it’s all installed it will not start display on Dash says low power mode the thing is it cranks fine and fires but will not run
it’s giving me a throttle position code so I replace throttle body with position sensor no better then gas pedal sensor same no better replaced ignition switch today still nothing Could it be a computer issue I have replaced all sensors too
Old Jul 19, 2025 | 10:11 PM
was the engine from an 07? cam position changes from older to newer. some hve one some have 2 sensors.
Old Jul 19, 2025 | 10:13 PM
BLK07H-3's Avatar
It’s a o7 motor and both cam sensors are new
Old Jul 19, 2025 | 10:21 PM
did they do a crank relearn yet?
Old Jul 19, 2025 | 10:41 PM
BLK07H-3's Avatar
No I was told it has to run to relearn is that True?
Old Jul 20, 2025 | 10:50 PM
yes it is true.
make sure all the bulk head connectors are seated properly especially the fuse box. check for bent pins snd corrosion. and make sure you have not missed any ground points. the harness are old and brittle maybe moving them something got pinched or pulled. especially the wiring going down to the transmission.
Old Jul 21, 2025 | 12:57 AM
BLK07H-3's Avatar
I’ll be checking all that thank you
Jbrashers
Nov 21, 2019 09:32 AM
ski.dive
Mar 6, 2019 04:18 PM
Terrielle
Aug 12, 2018 03:13 PM
Alex Polazzo
Jul 3, 2017 12:42 PM
h3carlos
Dec 30, 2013 01:14 AM
