Hummer H2 SUT For some who need the usefulness of a truck, but do not want to compromise the Hummer look, the H2 SUT does just that.
Tank fuel line disconnect tool
Old Jun 11, 2019 | 07:44 PM
austinwae's Avatar
Default Tank fuel line disconnect tool
Hello All. I have a 05 SUT and I'm in the process of replacing the rusted out fuel pump from within the tank. I can't find the correct fuel line disconnect tool.
Any ideas will be greatly appreciated. Looks like a snap on..
Old Sep 24, 2019 | 03:18 PM
oceanbrave's Avatar
Just so happens I'm about to do the same job on my SUV.
I asked the same question and I was told not tools required, if you find something let me know. Perhaps a piece of plastic with a notch in would suffice?
BTW what fuel pump model have you purchased?
Old Sep 24, 2019 | 04:19 PM
coffeydp's Avatar
I just completed this on my '03 SUV. I cant imagine the pumps and lines aren't the same. You do not need a special tool, you simply pinch the plastic tabs that are on the end of the connector. I had an issue where the metal line was stuck inside the plastic line. There is a plastic washer that seized onto the metal fuel pump line, I had to cut the line and work it out with pliers.
Old Sep 24, 2019 | 08:17 PM
Old Sep 24, 2019 | 08:30 PM
I never needed to cut, spray penetrant, pinch, wiggle, pull, release.
Old Feb 17, 2024 | 03:22 AM
Hmmr's Avatar
Hi Oceanbrave,
I hope you are well, it's been a long time, my air suspension is working perfectly, thank you again for all your help.
However I would appreciate your help again if possible, I have purchased a new fuel pump as it stopped providing fuel levels, the transmitter or float must have failed so I purchased a replacement unit and taken the opportunity to upgrade the fuel pump to a 65PSI pump (my motor upgrade has always shown signs of fuel starvation on full throttle) my problem as per the austinwae the thread starter, I can't remove the 5/8 line off the pump. A standard fuel line tool does nothing and pinching the two tags on the line also don't release it. How do I remove it, any suggestions would be appreciated.
The pump I have is similar to the one shown by austinwae with a fuel outlet and a 5/8 outlet, I believe this is a breather line or possibly a return line
Old Feb 17, 2024 | 04:54 PM
the o-rings are probably stuck onto the pump fitting. try using a penetrating fluid and movement on the hose if possible.
Old Feb 18, 2024 | 02:59 AM
Hmmr's Avatar
Thank you, it worked.
Old Feb 18, 2024 | 03:43 AM
oceanbrave's Avatar
Hi Hmmr, yes been a while, all good here in UK, hope things are OK where you are.
Thanks to bronxteck's suggestion it looks like you've sorted your Evap line.
As fyi @ 13.21 time mark is a similar issue in this video, hope yours wasn't as bad.
h2hummer5
Aug 9, 2019 11:57 AM
jakeys1999
Apr 13, 2018 08:51 AM
ingydrummer
Jul 8, 2014 06:17 PM
dscaberboy
Oct 8, 2007 04:52 PM
