Tank fuel line disconnect tool
Hello All. I have a 05 SUT and I'm in the process of replacing the rusted out fuel pump from within the tank. I can't find the correct fuel line disconnect tool.
Any ideas will be greatly appreciated. Looks like a snap on.. https://cimg1.ibsrv.net/gimg/www.hum...435b73f3f3.jpg |
Just so happens I'm about to do the same job on my SUV.
I asked the same question and I was told not tools required, if you find something let me know. Perhaps a piece of plastic with a notch in would suffice? BTW what fuel pump model have you purchased? |
I just completed this on my '03 SUV. I cant imagine the pumps and lines aren't the same. You do not need a special tool, you simply pinch the plastic tabs that are on the end of the connector. I had an issue where the metal line was stuck inside the plastic line. There is a plastic washer that seized onto the metal fuel pump line, I had to cut the line and work it out with pliers.
Originally Posted by coffeydp
(Post 364821)
Hi Oceanbrave,
I hope you are well, it's been a long time, my air suspension is working perfectly, thank you again for all your help. However I would appreciate your help again if possible, I have purchased a new fuel pump as it stopped providing fuel levels, the transmitter or float must have failed so I purchased a replacement unit and taken the opportunity to upgrade the fuel pump to a 65PSI pump (my motor upgrade has always shown signs of fuel starvation on full throttle) my problem as per the austinwae the thread starter, I can't remove the 5/8 line off the pump. A standard fuel line tool does nothing and pinching the two tags on the line also don't release it. How do I remove it, any suggestions would be appreciated. The pump I have is similar to the one shown by austinwae with a fuel outlet and a 5/8 outlet, I believe this is a breather line or possibly a return line |
the o-rings are probably stuck onto the pump fitting. try using a penetrating fluid and movement on the hose if possible.
(Post 407108)
