Old Apr 2, 2017 | 09:03 PM
  #501
pinnacom's Avatar
Default Added LED Headlights
Replaced the 7" round headlights with LED headlights for a Jeep.
Photos as soon as all finished.
Old Apr 2, 2017 | 10:57 PM
  #502
therealdougkelly's Avatar
Yes pics please!
I'm interested in doing this mod as well.. what brand did you go with?
Old Apr 3, 2017 | 07:08 AM
  #503
I put LED headlights on mine. See this post #33
https://www.hummerforums.com/forum/h...e4/#post341771
This very specific one is not the easiset to find. I'm told some brand here in the USA or Canada bought the rights to these from Tuff Plus and as such the supply of them (at a reasonable price is drying up). I did locate a seller on eBay with them. As I mentioned in that other thread - a lot of research was done on these specific ones on a Jeep forums. The model number is A0101 but multiple Chinese LED headlights are using that same model number so that will not really help you definitively find these specific ones if you want to find them.
This listing has the exact right pictures with the correct packaging shown and in chrome.
2x 7" Round Cree LED Headlight High Low Beam Angle Eye for Jeep Wrangler TJ JK | eBay
There is another seller on eBay with the black ones for the lowest I've ever seen for them. They are not clear in the listing that you are buying a pair nor do they show the packaging though. If I wanted a black set I'd contact this seller and send them the picture of the box from the other listing and see if they will confirm that its the same packing. They do show the DOT mark on the lower left edge and they look right though.
1997-2017 Jeep Wrangler JK CJ TJ CREE LED DRL Lights Headlights 7" Inch Round | eBay
These have a specific look, no halos and have the two double sections on each side, not a flat bar on each side. Many look the same but on close inspection they are not exactly the same and there are huge differences in the quality on LED headlights.
In the other thread I linked above you can see where I had to cut the plastic bucket to install them. This is them installed.... I only have a poor beam shot from a cell phone though. Its much clearer in person. What I like a lot about these specific ones is the proper razor sharp cutoff like you generally see on HID headlights.
Attached Thumbnails What have you done to your h2 today?-img_0771.jpg   What have you done to your h2 today?-img_20170125_175457687.jpg
Old Apr 3, 2017 | 08:07 AM
  #504
Thanks for the info. I think I'll jump on the black ones soon before they are all sold out!
Old Apr 3, 2017 | 08:41 AM
  #505
mcioci's Avatar
I had to put silicone under my cab lights due to water coming into truck after 2 days of bad rain. Hoping this does the job.
Old Apr 6, 2017 | 08:32 PM
  #506
legerwn's Avatar
Raised the front with the torsion bars (first shot was to much, had to lower them a bit).
Learned how to use the remote start correctly, also learned that if the MIL for certain reasons the remote start will not work.
Added Hummer software to my scanner so I can play and troubleshoot things
Working on getting the brake dust off the wheels
Put new seals on the inner front and rear clearance lights and sealed the corner lights with sealant
that was enough for a good while
Neal
Old Apr 7, 2017 | 08:40 AM
  #507
H2Miami's Avatar
Neal
Good job . Dont forget to get alignment and adjust the headlights after front is raised
Old Apr 7, 2017 | 11:16 AM
  #508
legerwn's Avatar
thanks for the heads up,
its on the list prior to getting the new tires
Neal
Old Apr 7, 2017 | 01:17 PM
  #509
dontheo55's Avatar
Took out the center console and pulled out the onStar unit. Plan to hook up the Mic and GPS antenna feed to the Pioneer App Radio.
I want to put in 6 toggle switches in the space the OnStar unit occupied. May try using the face plate from the OnStar Controls or fabricating something to fit.
Ted
Old Apr 7, 2017 | 02:12 PM
  #510
The mic and GPS antenna from the Onstar will work great with your aftermarket head unit. I used them for my Kenwood.
You will just have to splice into the mic wires, and either get an adapter or cut the GPS connector off and install the one your Pioneer uses.... The GPS antenna cable does not leave you much extra length once you route it up to the radio pocket but it works great.
On mine - I took it to a tire shop yesterday and had them swap my ties over a a set of excellent factory chrome wheels. I felt too old to be running around with Rockstar wheels... plus I'm not fond of the mostly black wheels that I now see on 3 out of 4 trucks nowadays.
Anyone near Columbia SC interested in a set of perfect condition Rockstar wheels shoot me a message.
