Old May 7, 2015 | 08:06 PM
  #101
liveinxs's Avatar
Banned
Originally Posted by Dieseldrums
I took out the bolt on the drivers side of the fan shroud that holds them together and the lower part rotates up into the top part. Didn't have to mess with anything else. I need to fab up some spacers for between the rear bumper and the body now tho.
I see, thanks for the explanation...
Would it be possible to get a few shots of the Hummer, i would like to see how it looks...
also i am curious, just where did you jack up the body, is there an areaa under the body, that you can recommend...
thanks Eric
Old May 8, 2015 | 06:31 PM
  #102
Dieseldrums's Avatar
I had access to a lift but you can do it with jacks....2 per side. I cut some long 4x4 pieces of lumber and jacked them up into the body. There is no particular spot to jack the body so use a flat piece of wood to distribute the weight best you can.
I had to really jack the rear up high to fit the spacers in back there.
The pics don't do it justice....I feel like I'm a mile higher driving it now and it looks great with the stock wheels.
Attached Thumbnails What have you done to your h2 today?-20150508_190351.jpg
Old May 9, 2015 | 04:53 PM
  #103
madmayo's Avatar
Went night wheelin. First time in mud with the toyo at2. They did not perform well And clogged up easily. Had to get tugged out by an f250 powerstroke. Thankfully I got to return the favour later on. Hill climbing I also wasn't impressed. Wishing I didn't sell my stock rims now. Should have mounted some 37 m/T's for such occassions
Old May 9, 2015 | 10:29 PM
  #104
mcioci's Avatar
Installed brake pads al around and kryptonite upper control arms. Huge diff in ride wow. Painted my side view mirrors black. Put Bedliner on my 2 roof rails.
Old May 10, 2015 | 10:03 AM
  #105
H2Miami's Avatar
Rear rotors and brake pads replaced .
Oem rotors were rusty to die .
pads in worse cond .
glad didnt have a problem in Tennessee mountains a month ago
Old May 10, 2015 | 10:45 AM
  #106
Synthetickiller's Avatar
This is why I'm always mentioning the AT2s in a negative light. I had the same thing happen on the Ram 2500 I sold. Those tires suck in mud & really just suck as a whole. They don't wear quickly, but since they wear like iron, they ride like iron too.
If you sell the AT2s, what will you get?
The MTR looks like a nice mud tire vs some of the offerings of others, but I have no experience with it, yet.
What do you think the problem was that improved the ride quality? I wouldn't think control arms would matter unless there was a lot of play.
Post some pics anyways! I want to see how they look. This is on my to-do list.
I'll be doing this soon.
I've only been hesitant, as I want to replace basically all of the front suspension (ball joint, control arms, idler, pitman, etc) & would rather not have to remove everything all over again.
Old May 11, 2015 | 10:29 AM
  #107
liveinxs's Avatar
Banned
I see a lot of people replacing the UCAs, just why are they needed to be replaced, outside of just a better quality item, or do they help with lift of front end, i have traxda keys installed, will UCAs help in getting more height
Old May 11, 2015 | 09:12 PM
  #108
Depends on your set up.
Moog has an UCA that allows for dual shocks to be mounted.
Other custom UCAs are built for suspension lifts; that's correct.
The duramax store has kryptonite UCAs that, according to reviews, really improve the ride quality, especially over bumps.
Ball joints, bushings, & bump stops get worn. Bumpstops are not the real issue here, but ball joints & bushings can cause problems. Look at your differential crossmember. If you have shaking in the steering wheel & pedals, that could be the cause. And that's my point, it's a ride quality issue.
I'm replacing mine for the 3rd reason.
The owner of my current H2 beat the poor thing to hell & basically everything in the suspension is being replaced. Once I get it installed, I'll update on my experience. The bushings are all dry rotted out & I believe the ball joint is shot. I'll know for sure once everything's replaced.
Old May 11, 2015 | 09:41 PM
  #109
liveinxs's Avatar
Banned
Thanks for info, sounds like a great project, i checked out the Krytonite UCA, they are sweet looking, especially in Red, thats gonna ethe color I'll go with, when i buy them, will match my Red Calipers. ..
The following link, has a crazy set up for the front end, DMAXSTORE Ultimate Front End Package Stage 3 | DMAX Store
Old May 11, 2015 | 10:37 PM
  #110
I really wish you hadn't done that!
I really don't want to have to drop $1600 (if it's $1400, might as well drop $200 more on the upgrade). I might have to justify the cost though, as I need to rebuild all of it anyways.
I wonder if the swaybar endlinks are better than stock.
I have the endlinks provided by hellwig & they are good. The whole kit was $130ish for the front as well as the end.
I need some endlinks for the back, though. I wonder if there exists an upgrade. I haven't seen one yet.
I'm really debating between the black or red UCA. I'm not sure yet. Red matches the adjuster on my shocks. Black blends in. I'd probably do the LCA in the same color.
Speaking of which, did you see the Kryptonite LCA? It's a $900 set!
