Water leak passenger side :(
Old Jan 12, 2020 | 01:24 PM
There are many vids on YT that shows were the common leaks are. Why not address them all and be done with it! Just grab your caulking gun and a get a tube of Silicone Max Clear 100% Premium Window, Door and Siding Silicone Sealant, and go to the areas noted, clean/prep area and caulk.
Old Jan 12, 2020 | 09:10 PM
hummer_on_fumes's Avatar
I had the same problem and had to silicone the top of the molding from the outside to stop the leak
Old Jan 12, 2020 | 09:14 PM
Old Jan 13, 2020 | 12:11 PM
2005H2's Avatar
so you filled in the channel with sealant? is that where the water is supposed to drain to?
Old Jan 15, 2020 | 03:54 PM
indeedido's Avatar
What did you do to the roof marker lights? I believe I have the same problem. Did you get new grommets?
Old Jan 15, 2020 | 04:35 PM
Rather than trying to find replacement grommets, most just go to town using silicone and push the original grommet into it - that is what I did, and it hasn't leaked once in years
Old Jan 15, 2020 | 09:12 PM
Nice work on the oem upgrade!
devanwon
Aug 21, 2023 05:08 AM
RAHF
Feb 6, 2015 10:26 PM
budryzer
Feb 16, 2014 07:12 AM
triciah
May 30, 2011 09:41 PM
