stay with Dot 3 or upgrade to Dot 4/5?
Old Feb 19, 2020 | 02:08 PM
hnijhar's Avatar
Default stay with Dot 3 or upgrade to Dot 4/5?
going to be bleeding the brakes and putting in some new fluid, since i am draining all of it. should i stick with dot 3? or is it better to upgrade to dot 4? or dot 5 etc
what are you guys running?
thx
Old Feb 19, 2020 | 03:58 PM
hnijhar's Avatar
JOHNSEN'S2232Premium DOT 3
i can get this pretty cheap from rock auto so will prob go with this unless you guys recommend the delco fluid over aftermarket but what ive heard is all brake fluid is essentially the same!
Old Feb 19, 2020 | 04:04 PM
tharber's Avatar
Dot 3 is compatible with 4 and 5, difference is boiling point. Dot 5 will not absorb water so that's the biggest advantage. I don't think you can completely remove all the old fluid without having a Tech2 to bleed the anti lock but I'm guessing. When I upgraded my brake system I went with Dot 4 and just bled the snot out of the system.
Tim
Old Feb 19, 2020 | 04:24 PM
DO NOT USE DOT 5! UPGRADE to DOT 4 or DOT 5.1
Old Feb 19, 2020 | 04:39 PM
hnijhar's Avatar
sounds good thanks!
newh2owner
Nov 17, 2018 10:13 AM
Jerzey
Jul 22, 2017 06:27 PM
PaulsH3
Apr 12, 2011 11:24 PM
HummerHummer.co.uk
Sep 10, 2009 11:44 PM
MattC124
Aug 19, 2009 09:34 AM
