Shut down
Old Jan 4, 2025 | 11:28 AM
Tatman54's Avatar
Default Shut down
Hey all.... so a couple weeks ago my hummer 03 H2 was running g great as usual. Doing 75 on freeway with cruise on. Then I felt a fumble and a few seconds later it did it again. Then the third time I moved over to right lane and tapped break to turn cruise off. It literally stopped running g at that point and I pulled over. I had 0 codes for cam or crank sensor and I'm getting fuel. Cam, fuel pressure regua
lator and crank are really only culprits i can think of as my fuel pump is running and it tries to fire. I guess my question is what could do this with absolutely no warning? Like I said it was running great and I had no warning signs of anything... ecm or pcm? I hate to throw parts at it but those are only things I can think of. I did change fuel filter for grins... anyway long diatribe I know, but thanks for any thoughts or suggestions....
Old Jan 4, 2025 | 03:24 PM
the engine wont run if the coolant sensor is bad or bad wiring to it. check your temps with a scan tool that shows live data. also if the MAF sensor is having issues you can disconnect it and see if it starts then. or maybe it is a bad chassis grounding issue. need to check your ground points and straps.
Old Jan 4, 2025 | 04:36 PM
Tatman54's Avatar
Well I can't do live data as it won't run.. but i will check maf sensor later.
Old Jan 4, 2025 | 07:05 PM
RobertDez's Avatar
I'd be inclined to suspect something electrical. Start by verifying all your grounds.... And harness connectors.
Old Jan 4, 2025 | 08:53 PM
well the temp sensor should at least give you the ambient temperature. unless it is way too cold where the truck is located.
bassackwards
Oct 27, 2021 06:30 AM
Licjhondelacruz
Mar 23, 2019 05:48 PM
Oldgreen72
Apr 3, 2018 01:02 PM
2003hummerCHIC
Jun 1, 2011 12:40 AM
dscaberboy
Jan 27, 2009 06:28 AM
