Sealing the roof light leak
Old Jun 7, 2024 | 12:06 PM
  #21
HarleyWrase's Avatar
Originally Posted by Gavin Costigan
Im at the point where I'm going to cut the wire and weld the damn hole shut. Then run wires down the molding on the outside of the truck that goes under the hood and tie them into the fuse box. It was pouring down rain today and I'm pissed about having to wipe my dash off every 5 minutes.
my mechanic proposed the same thing, lol. I wonder if newer model gmc 2500 series with clearance and markers have a better solution now?
Old Jun 10, 2024 | 02:43 PM
  #22
HellHoof's Avatar
I bought a roll of Flex Seal tape to try sealing up the grommets where they come through the roof. Cut a square of tape, and cut a slit halfway across. Slide the wire through the slit, and stick it down. Then repeat, turning the tape around 180 degrees, so the slit on the first piece is covered, and the slit on the second piece is over the first piece of tape.
Hopefully this works.
Old Jun 16, 2024 | 07:01 PM
  #23
Old Jun 16, 2024 | 08:19 PM
  #24
Mark R's Avatar
Originally Posted by HarleyWrase
Old Nov 4, 2024 | 12:47 PM
  #25
HellHoof's Avatar
5 month follow up:
It took forever to get some rain but we finally did. I parked it outside and the interior is as dry as can be - I gotta say this worked well.
Old Nov 4, 2024 | 08:18 PM
  #26
RobertDez's Avatar
3M 5200 is the best stuff you can get for a sealer. They make it for below the water line hull fittings on boats. But there's a warning. You'll end up breaking your marker lights if you ever try to remove them. The stuff is like permanent.
Old Nov 4, 2024 | 08:21 PM
  #27
RobertDez's Avatar
3M 5200 on Amazon
3M Marine Adhesive Sealant 5200 (06500) Permanent Bonding and Sealing for Boats and RVs Above and Below the Waterline Waterproof Repair, White, 10 fl oz Cartridge https://a.co/d/3QhMrob
Old Nov 5, 2024 | 09:38 AM
  #28
HellHoof's Avatar
You should be gluing the grommet where the wire goes through the roof - not the light to the roof rail.
Old Nov 5, 2024 | 10:11 AM
  #29
RobertDez's Avatar
Correct. Use it in the places the water actually intrudes into the cabin. Yet how many times have we seen marker lights with massive amounts of RTV sticking out from under the edges? Also it should be noted that RTV isn't exactly great stuff on painted metal. Often leads to corrosion.
Stevegt17
Mar 23, 2024 05:20 PM
Riccardo Soff
Jan 23, 2018 09:26 AM
hmer
May 28, 2014 08:57 PM
Firepilot2
Jul 19, 2011 06:32 PM
XENO
Jun 19, 2011 12:04 PM
