Water leak driver side
Old Jul 2, 2021 | 03:05 PM
Stevegt17's Avatar
Default Water leak driver side
Water leak driver side handle coming from corner of the roof on drivers side. I’ve silicones the cab light holes and it’s still happening. Any advice is appreciated. Thanks
Old Jul 2, 2021 | 05:46 PM
drivers front sunroof drain may be disconnected on that side or the corner roof light grommet needs resealing. might want to also check the door seal right at that corner.
Old Jul 2, 2021 | 06:45 PM
Stevegt17's Avatar
Thanks for the response. I’m going to try to reseal the door seal and see what happens. It is coming off a bit so hopefully this fixes it
Old Aug 18, 2021 | 01:54 PM
Stevegt17's Avatar
Just an update. I have sealed every light but I still get water on the driver side pulled just above the handle just at top corner of the headliner. Can It be possible water is coming in from the windshield? I also checked sunroof drains. If I run a hose on the top of cab light water comes in. What else can I do?
Old Aug 18, 2021 | 06:24 PM
Direct the water to the top of the windshield only and recheck.
Old Aug 18, 2021 | 09:40 PM
Stevegt17's Avatar
Thanks. I’m going to use a water bottle so I have more control of where the water goes
Old Aug 21, 2021 | 12:49 PM
Holly Lake H2's Avatar
Default proof. Leak on H3 is almost always the sun roof drain.n
The drains run down both sides of the veh. Each are metal and connect to plastic hose.. If you blow through the tube to unstop it blows off the tubing and leaks into the floor board. If run a wire down it it does the same. Look up on internet to find where tube meets hose and glue hardened plastic back on and it will stop. I found this out after siliconing every hole in the outside of my H3. It can also leak directly into the fuse box on the left kick panel and short the battery . These fandom battery drains usually happen on wet or rainy days. both problems are inner connected. If this fixes your H3 sell it before the front cylinder loses all of its compression. James
Old Sep 4, 2021 | 11:31 AM
Stevegt17's Avatar
This water leak has turned into a nightmare. I’ve done everything and even had the windshield and molding replaced and it is still leaking. The windshield shop told me it’s the pinch welds and I should take it to the body shop. Has anybody ever heard of this and is it a expensive fix.
Old Sep 4, 2021 | 06:16 PM
if you now where it is then you might need to reseal it with fresh seam sealer.
Old Sep 8, 2021 | 10:43 AM
syphondog3's Avatar
Can you post pictures of the leak area? I'm curious about how you will resolve this as well. I worry about this stuff as well for my 03...
