Running lamp issue '07 h2
Old May 24, 2023 | 04:10 PM
Jbelleye408's Avatar
Default Running lamp issue '07 h2
Driver's side Running lamp
Replaced bulb, fuse... still not working. Any insight?
Apologies in advance if this is a redundant question, at least I'm in the correct section!!
Old May 24, 2023 | 05:28 PM
zenith's Avatar
I'd check the bulb socket itself. Over time these sockets may get moisture in there and small rust builds up. Maybe see if the bulb is firmly seated in the socket and all the socket prongs are not collapsed or not contacting the base of the bulb. Other than that, maybe wiring harness has small short, or ground wire needs to be re-grounded (cleaned).
spokulok
Sep 21, 2023 01:18 PM
H2Finally
May 2, 2023 09:58 AM
rhill20
Sep 12, 2014 04:53 PM
Chubosco
May 13, 2011 08:56 PM
Koolaid
Apr 11, 2009 12:43 AM
