Recommendation for a HT starter for my H2
Old Jan 30, 2020 | 08:56 AM
H2THEHARDWAY's Avatar
Default Recommendation for a HT starter for my H2
I have a 2005 H2 6.0L and the starter is having difficulties turning the motor over and dims lights with cranking cycle which is slow. Installed a new Odyssey 1100CCA battery last week, it works better but still has a slow tough time. Im thinking a high torque starter but would like some recommendations. Thanks for your insight.
Old Jan 30, 2020 | 11:39 AM
Sam!'s Avatar
Starter might be worn and a simple OEM or rebuilt OE replacement would do.
Old Jan 30, 2020 | 12:36 PM
thanks
I will look into a GM replacment
Old Jan 31, 2020 | 07:59 AM
calif phil's Avatar
Not sure where you live but if it is really cold, too thick of oil can make it turn over slower, I would also bet, it's the starter like you think it is, but I thought the temp. aspect was worth mentioning.
Old Jan 31, 2020 | 08:56 AM
thanks
run amsoil full synthetic 5w30 for 10yrs, this is the second starter so im sure its cheap as I was in Moab and it went out and got whatever they had. I didn't know if going to a High torque/energy would help to add performance or just a upgrade?
Old Jan 31, 2020 | 07:58 PM
First check/clean connections @battery & starter!
Old Jan 31, 2020 | 09:34 PM
Sam!'s Avatar
https://www.youtube.com/watch?v=U_NMz8zLeJg
And Ground at motor block and battery terminal
Old Feb 3, 2020 | 08:00 AM
thanks checking that out
edwin2010
Apr 9, 2018 10:47 AM
CARdiac
Oct 18, 2015 02:11 AM
Blake0496
Oct 11, 2013 03:40 PM
BiG_Ze
Aug 10, 2012 09:03 AM
tx_pilot
Nov 22, 2010 06:12 PM
