problem starting my h2
Old Mar 21, 2019 | 03:38 PM
Licjhondelacruz's Avatar
Default problem starting my h2
hello guys I have a h2 03', but im having problems starting it, went i tried to start the engine I have to tried twice and some times more than that, but went it start the engine function pretty well, sooo i check the fuel pump but its ok, I replace the fuel filter, and also the fuel pressure regulator... anyone have an idea of what could be?
Old Mar 21, 2019 | 03:47 PM
BowerPower's Avatar
What you described sounds like a fuel pump. How did you determine the fuel pump was ok?
Old Mar 21, 2019 | 04:11 PM
because i replace it with a new one, and a new fuel filter, an also after it start it runs perfectly, im just using the old fuel pump housing
Old Mar 21, 2019 | 04:13 PM
because it was replace for a new one went i change the fuel filter, the only old thing that im using is the fuel pump housing
Old Mar 21, 2019 | 08:15 PM
BowerPower's Avatar
It sounds like a fuel problem to me. Just because the pump is new doesn't mean that it is good. You need to check fuel pressure before start and at cranking. Just because it runs fine doesn't mean the fuel pressure is adequate to start the vehicle. Most part store will let you borrow a pressure gauge.
Old Mar 22, 2019 | 07:58 AM
calif phil's Avatar
A fuel pressure test is a must, cleaning your throttle body would be another good idea.
Old Mar 22, 2019 | 09:40 AM
thanks for the advice I'm gonna do it... I'll let u know the results
Old Mar 22, 2019 | 09:41 AM
i did it in the past but I'll repeat it to see if that works
Old Mar 22, 2019 | 06:16 PM
legerwn's Avatar
Leaking injector causing flooding when shutoff and allowed to sit
Check the fuel tank pressure, if the purge solenoid leaks and the vent solenoid does not open then fuel vapors will accumulate in the intake from vapor pressure from the tank and cause hard start issues (this will usually cause a fault code)
Neal
Old Mar 22, 2019 | 07:24 PM
BowerPower's Avatar
Neal
leaking injectors would only effect the start if the vehicle is warm and had been sitting for an hour or two. If you're having troubles only when it is warm, push the accelerator to the floor with the key on then start. That puts the vehicle in flood clear mode and see if it starts better.
