problem starting my h2
hello guys I have a h2 03', but im having problems starting it, went i tried to start the engine I have to tried twice and some times more than that, but went it start the engine function pretty well, sooo i check the fuel pump but its ok, I replace the fuel filter, and also the fuel pressure regulator... anyone have an idea of what could be?
Originally Posted by Licjhondelacruz
(Post 359004)
because i replace it with a new one, and a new fuel filter, an also after it start it runs perfectly, im just using the old fuel pump housing
Originally Posted by BowerPower
(Post 359006)
What you described sounds like a fuel pump. How did you determine the fuel pump was ok?
(Post 359008)
because it was replace for a new one went i change the fuel filter, the only old thing that im using is the fuel pump housing
A fuel pressure test is a must, cleaning your throttle body would be another good idea.
(Post 359023)
It sounds like a fuel problem to me. Just because the pump is new doesn't mean that it is good. You need to check fuel pressure before start and at cranking. Just because it runs fine doesn't mean the fuel pressure is adequate to start the vehicle. Most part store will let you borrow a pressure gauge.
(Post 359026)
Leaking injector causing flooding when shutoff and allowed to sit
Check the fuel tank pressure, if the purge solenoid leaks and the vent solenoid does not open then fuel vapors will accumulate in the intake from vapor pressure from the tank and cause hard start issues (this will usually cause a fault code) Neal |
Originally Posted by legerwn
(Post 359044)
