Part number help for bolt
Old Apr 9, 2020 | 04:21 PM
Kavik001's Avatar
Default Part number help for bolt
Hey guys I need help with a part number for a Bolt & Nut for my H2. It's the bolt that secures the torsion spring crossmember to a bushing bracket on the inside of the frame rail. I've attached a picture . I looked through every Hummer parts diagram I could find and I can find the crossmember but I can't find the part number for this particular bolt, it's stripped so I can't get my H2 back together. Help appreciated . I tried to match it up at the local specialty nut and bolt shops but they're all closed because the Covid, so I'm going to have to mail order one
Old Apr 9, 2020 | 06:15 PM
iwillnc's Avatar
That will throw you off, asking about an H2 part but showing the part in the center console of an H3 🤣
I would try going to the dealer, I’ve found that they have a much more complete parts diagram in their system than anything you can find on the web. iirc the door panel clips are dealer parts diagram only for example.
Old Apr 9, 2020 | 06:27 PM
Kavik001's Avatar
I confess!! I currently have one of each- I have a 07 H3 that's up to 170K now, so I found a low milage 04 H2 to eventually replace it with.. I tried local chevy/GMC parts guys but they are also currently closed..
Old Apr 10, 2020 | 06:56 AM
iwillnc's Avatar
That’s odd, I went to the dealer yesterday and had my brake fluid changed, dealerships are considered essential, not sure why they would be closed.
Old Apr 10, 2020 | 04:01 PM
just go to a hardware store and have it matched up. there is nothing special about it other then maybe being a grade 8 bolt.
Old Apr 10, 2020 | 10:16 PM
Class 10.9 - M10-1.5
Chrmer3
Feb 1, 2020 07:55 PM
mcsahib
Mar 6, 2018 12:58 PM
Malcolm745
May 24, 2016 03:28 AM
motion vega
Sep 20, 2013 02:40 PM
ambernty
Mar 22, 2013 10:34 PM
