h3 pinch bolt blues
Old Sep 18, 2013 | 07:47 PM
motion vega's Avatar
Default h3 pinch bolt blues
was gonna swap my arms tonight but bolts are seized. nuts came off ok. do these things thread into the spindle to or just the nut? im gonna order new ones tomorrow and take care of it monday, just curious abotu the threads before i start wailing on things.
Old Sep 18, 2013 | 11:25 PM
happythree's Avatar
are you saying you cant turn the bolt after the nut came off?
I thought most could be driven out but the (crappy) drawing in the book looks like it could be threaded in the assm.
try turning , it should rotate, if it don't thread out bump it with the nut part way on to protect the threads to loosen it.
heres what the book says.
Remove and discard the upper control arm pinch bolt and nut from the ball joint.
9. Remove and discard the lower control arm retaining nu
lotta help
Old Sep 19, 2013 | 07:34 AM
yeah it wont turn at all. sprayed it with deep creep and put the nut back on
Old Sep 19, 2013 | 07:48 AM
happythree's Avatar
impact wrench?, 2 ft extension pipe?
I have pipe that fits 1/2 in drive breaker bars just in case!
let us know
Old Sep 19, 2013 | 10:45 PM
gonna go after it monday with the bigger compressor at the shop.
Old Sep 20, 2013 | 02:24 PM
It has been a good three years since I messed with an H3 pinch bolt, but I do not recall it being threaded in. I'm thinking you just have a serious case of dissimilar metal corrosion. I would still try to turn it because that will assist in breaking it free.
This is where the H3 meets the 3 Hs. Heat, Hammer, and Holler!
Old Sep 20, 2013 | 02:40 PM
Thinking about it more............ the pinch bolt is 1000% not threaded, it has threads only on the nut end and its smooth sides are what is in the notch in the ball-joint shaft.
Start wailing.
midwest
Feb 14, 2012 10:28 AM
palmid
Dec 29, 2010 11:29 AM
hummer
Aug 28, 2007 02:30 AM
hummer50
Feb 15, 2006 09:52 PM
hummer50
Jan 11, 2006 08:59 PM
