P0171 lean condition.
Old May 4, 2024 | 12:30 PM
JWoody's Avatar
[QUOTE=JWoody;408273]do the O2 sensor MV's swing high and low while idling?
most i seen was 0.850 and lowest i seen was 0.090. i also check MAF readings and im getting 0.90 lb/min at idle. only raises up to about 4lb/min under load.
Old May 4, 2024 | 01:00 PM
legerwn's Avatar
I would have the exhaust leaks repaired prior to going any further to make sure this is not causing your issue.
as long as the MV's are switching back and forth then its doing what it should,
.90 lb/min is in the ballpark for the 6.0L at idle in park or neutral
can you see the injector pulse width on your scanner, if so are both banks close?
Looking at the wiring diagram the only common wire for the O2 sensors is the power wire, don't see how one sensor can effect the other through wiring.
if you can clear codes with your scanner then try unplugging the MAF sensor after cranking the truck, it will through a code but you can clear it. this will put the truck into speed density which will cause it to stop using the MAF for fueling. After unplugging the MAF look at the trims then and see what they do, pay attention to how the truck idles after unplugging the MAF.
Neal
Old May 4, 2024 | 01:52 PM
JWoody's Avatar
with MAF unplugged the truck runs even worse. bogs and won’t get up to speed at all.
Old May 4, 2024 | 06:39 PM
like i mentioned tighten your intake manifold bolts before going to crazy. and if you can check your fuel pressure.
Originally Posted by legerwn
According to Mitchel DIY, of over 60 reported repairs for the P0171 DTC, the 2 top causes are the Mass air flow sensor and the O2 sensor as long as there are no other DTC's.
I agree with HUMMERZ fix your exhaust leaks then re-evaluate, there is a list of possible causes with fuel injectors being number 3
Neal
Check this bulletin=>Fuel Trim System Lean
Old May 4, 2024 | 06:49 PM
Originally Posted by JWoody
that’s my next plan of action, i’m just resenting doing it because of how much of a pain they are, i don’t have access to a welder to get the ones that are snapped out.
Eurynomestolas
Jun 8, 2023 10:10 AM
Mikenoland2019
Oct 31, 2022 10:15 AM
hummerz
Oct 10, 2020 03:10 PM
Alex2012
Oct 1, 2012 01:53 PM
HumminNBoatin
Nov 24, 2008 01:47 PM
