Overheating while towing fixed
Old Apr 5, 2019 | 08:14 AM
H2Miami's Avatar
Default Overheating while towing fixed
I was having an Overheating while towing (in tow mode)my 4000 pounds boat
Mostly while speeding over 50mph temperature was reaching the 235+
Easy fix . Replace the POS oem radiator for an aluminum one
Last towing trip 400 miles I pushed for a while to the 73mph and not issues
Temp was steady on the 195 all day
Old Apr 5, 2019 | 09:15 AM
KC Chief's Avatar
Can you post the brand you went with?
Old Apr 5, 2019 | 09:36 AM
H2Miami's Avatar
Old Apr 5, 2019 | 12:14 PM
KC Chief's Avatar
Sweeet, thanks!
Old Apr 7, 2019 | 08:56 PM
LoJac963's Avatar
Was it a direct fit along with all the lines?
Old Apr 7, 2019 | 10:47 PM
H2Miami's Avatar
Yes direct fit . No mods needed
I have an aftermarket tranny cooler so I didn't connected the lines but the fittings are there
Also gain the drain plug
And the temperature is smoother than ever
Great easy Improvement
Replace the radiator is fairly easy .
A few screws and hose clamps . The cross over which hold the hood must be removed . Make sure to tie the hood this is heavy
Old Apr 8, 2019 | 10:58 AM
LoJac963's Avatar
Great info!
Why does the hood have to be removed?
Thanks for the picture, I'm looking at a similar radiator with a dual electric fan setup with aluminum shroud. Hoping to get rid of the loud *** power stealing fan we have.
Old Apr 9, 2019 | 01:08 PM
H2Miami's Avatar
Not the hood but the crossover that hold the hood lines. That. Way you have enough clearance to remove the radiator .
Old Apr 9, 2019 | 07:34 PM
pitman's Avatar
What was the the temp before and after
Old Apr 9, 2019 | 11:16 PM
H2Miami's Avatar
195 steady. Not towing mode
Up and down Between 195 up to 235 while towing. Mostly when speed up over 55mph
Now .. 195 stay. Not matter what speed
BluHog
Nov 1, 2012 01:51 PM
DJONES
Jun 29, 2011 01:56 PM
countrysquireboy
Oct 25, 2007 12:57 PM
SarGuy33
Jul 13, 2007 08:05 PM
dave85c4
Mar 15, 2006 05:24 PM
