Oil pump failure on rebuilt Transmission 2nd time
Old May 15, 2022 | 01:23 PM
finall's Avatar
Originally Posted by 2004H2
Ripoff Dealerships suck, in my book.....and they wonder why they do not have any bussiness !!!
The real reason is that your area dealership has TOO MUCH business. They do not need yours. And they can charge whatever they want, and have enough customers to pay it.
If they charge 2x as much, they only need half the customers, to make the same money. And still have a service dept full of cars.
Sorry to hear about all your troubles. Obviously you have to keep searching for a better service outfit. Maybe most of them are bad where you live. Here they are pretty good.
Old May 15, 2022 | 10:54 PM
2004H2's Avatar
Default Tranny…
it they did not flush out the tranny cooler and lines debris might have got sucked into the pump. if they reused the torque converter and it had debris in it well same issue. so at this point you need a torque converter, and a cooler and line flush.
Hi, all new/rebuilt parts,flushed,rebuilt Torx-c, paid extra for an ss transmission,same as in ss sports trucks, corvette….rebuilt by dynamic Transmission, there more frustrated than i am, i still have a 2006 H3 we’re driving around, wifees truck….but his is getting old, its my TV, and cannot tow my trailer untill its fixed…and Trusted…..
will see what goes, im sure there tired of having it there,pulling out trans for 3rd time
2004H2
2006H3
Old May 16, 2022 | 04:29 PM
2004H2
2006H3
Ever tried spell check???? You have to pay more money for a warranty repair?????
Old May 17, 2022 | 10:05 AM
2004H2's Avatar
Default Spell check….lol
There is no extra money for the rebuilding of the Transmission, they pay for all the tows, and all the work, im just out of using my truck, and inconvenienced…..they called yesterday and said they found the problem, seems the new torque converter, they installed the last time had a hair line crack in the imput shaft, causing the pump to fail, last time the pump had shattered because the pressure regulator failed, and it should be ready on Thursday, hopefully….
i use an 8+ iphone, i do not have full screen use, im not perfect, just Forgiven……..
Old May 17, 2022 | 10:19 AM
2004H2's Avatar
Default Thank you…
Originally Posted by finall
"Demand a FULL refund out of pocket$ and take it to another shop! "
I agree. You should not have to go thru this much pain with your beautifully kept H2.
i try to keep our trucks like new, just now ive had to resort to buy parts from the junkyard, many interior parts are unavailable, so i get them from there…Waxed and cleaned every three months, paints almost like new, running toyo M/T on both hummers…..
Old May 17, 2022 | 07:20 PM
Who decides if a resilient adaptation is positive? What if resilience in the face of adversity comes at the expense of challenging a wrong?Resilience has been defined as a positive adaptation in response to adversity. Two researchers, Hamidah Mahdiani (University of Mainz, Germany) and Michael Ungar (Dalhousie University, Halifax, Canada), have pointed to the risks of this concept. They ask who decides if an adaptation is positive and warn of the risk of focusing on adaptation to an adversity at the expense of challenging that adversity.
Being resilient does not mean being invulnerable. Resilience and invulnerability are sometimes confused. For example, more educational support for children with learning disabilities may make them more resilient within a learning environment, but it will not make them less vulnerable to stigma or bullying.
Resilience may be displayed in ways that not all consider positive. Over-optimistic expectations that have little chance of being met – “false hopes” – can lead to failure, as can excessive self-reliance. Similarly, excessively high self-esteem can slide into narcissism. Resilience may manifest as a lack of appropriate emotional response to adversity, for example, in the case of bereavement.
A focus on resilience may distract from the need to challenge adversity rather than adapt to it – the resilience paradox. One could argue that adapting to climate change is counterproductive when the only safe response is to challenge it and try to stop it. The same could be argued for racism, poverty, violence, maltreatment, and social injustice. In all cases, resilience by a compliant individual may only make matters worse. This is called the resilience paradox.
Old May 18, 2022 | 07:53 AM
calif phil's Avatar
Sounds like the transmission shop is working hard at making it right, hopefully the 3rd time is the charm.
helicfii
Jun 6, 2022 11:16 AM
Stripp13
Jul 19, 2019 06:51 AM
H3owner78
Jun 11, 2018 09:32 AM
GarrettP1
Sep 10, 2013 07:26 PM
dscaberboy
Sep 26, 2008 10:11 PM
