Oil Leak located with dye photos. What part is it?
Old Mar 10, 2023 | 02:46 PM
Vax1op369's Avatar
Default Oil Leak located with dye photos. What part is it?
Hi H2 Team, Ran dye in the oil and took these 4 photos under uv light. Appears to be 2 bolts above the oil filter and 4 bolts on the direct opposite side where oil is leaking. Some bolts show more oil than others. Laying on my back with my feet towards the front of the vehicle. Does anyone why know why would be reaching this area on the passenger side? Looks directly to the right of the fly wheel. Any tips on how to stop it? Was going to tighten these bolts to start. Thx 4 tips. Cheers
3 leaking bolts. Top left was the worst.
Same photo as above but with fish eye view. 4 bolts in this photo
2 bolts leaking by oil filter
Photo after cleaning up dye of the 3 bolts
Old Mar 10, 2023 | 04:35 PM
oil pressure sender leaking oil and dropping down both sides? bad valve cover gaskets?
Old Mar 10, 2023 | 05:32 PM
Gavin Costigan's Avatar
That’s a pretty common place to find oil if it leaks basically from anywhere it all runs down to that spot.
common issues are valve cover gaskets and the oil pressure sender. Both pretty easy diy fixes. See if you can pinpoint higher up on the engine where the oil starts.
Old Mar 14, 2023 | 02:17 PM
H2-SUT's Avatar
Oil cooler block above the oil filter (drivers side) and pan gasket on the starter side(passenger side) that leaks down the starter bolts are also a possibility for a leak location
Hdog
Jun 26, 2022 05:13 PM
brucew@luxurylite.com
Jun 3, 2022 02:35 PM
Zco
Apr 2, 2022 06:50 AM
Kkneat
Feb 7, 2016 03:31 PM
stlH3
Nov 9, 2007 11:15 AM
