This Might Be A Boring Thread Or Poll
Old Mar 14, 2025 | 07:31 PM
RobertDez's Avatar
Yes sir. Go in equipped with a new gasket for your large marker light. When you lift that lens out, you'll see in Allen headed bolt under the front part of that lens cover. If you pull it out and the threads are a little rusty, you found it. And yeah, water just runs right under there. I assume there's several of those bolts the whole length of the roof rail holding it down. But with the forward rake of the vehicle, all the water runs to the front when parked. (And probably with driving, as I'm sure there's a vacuum effect from the back underside of that large lens)
Old Mar 14, 2025 | 09:12 PM
Mark R's Avatar
Well Robert, I think after all these years of hunting and sealing and even a new windshield under warranty you might have solved my problem. I had no clue there was an allen head bolt under there. And for sure the water uses that channel froward to drain thru the plastic outside molding. I have had that molding off years ago and it was clogged with pine needles caked in the shape of that underside molding.
So I bet that's it!!!!! That Fargen Bolt!!! I'll have to wait till it gets warmer and dive into that with a new gasket and some RTV.
Now......We have to start a Thread on the best way to clean the headliner. I have seen videos and you have to be careful not to soak the liner with to much wetness or the adhesive will break down. Hard to find a shop that will do a headliner. Especially a 20 Bazillion foot HUMMER H2! L.O.L.
That's for the tip.
Old Mar 15, 2025 | 09:24 AM
RobertDez's Avatar
Lol.... That's kind of how I found it, cleaning out all those damn pine needles.
I really had to wonder the logic of the gasket on that large marker light, since water freely flows in the channel under it.
Old Mar 15, 2025 | 01:57 PM
Mark R's Avatar
Yeah..in my frenzy of WTF was wrong, I took a piece of small gid screen door mesh amd rtv-ed it to the channel just before the marker lamp above. It stops the pine needles but not the water. Sort of like the operation where it was a success ...but the patient died.
Gavin Costigan
Feb 10, 2023 04:44 PM
Mr.G
Nov 5, 2021 11:45 PM
dontheo55
Mar 28, 2017 04:14 PM
Firepilot2
Jul 19, 2011 06:32 PM
SD90
Sep 16, 2009 01:40 AM
