Washing the Roof of the H2
Old Feb 9, 2023 | 12:00 PM
Gavin Costigan's Avatar
Default Washing the Roof of the H2
How are y'all washing your roofs? Mine has never been cleaned. With all of the baked-on pollen and dirt, it's very difficult. I can kind of get the edges with a mit, but trying to wash the middle is impossible since I can't really get enough reach and elbow grease even when standing on a tall ladder.
Definitely can not step on the roof either without denting or slipping and probably dying from that height.
Old Feb 9, 2023 | 12:20 PM
I use my 6ft stepladder and pressure washer to clean my H3 roof.
Btw, the roof is strong enough to support the weight of the vehicle.
Old Feb 9, 2023 | 02:32 PM
finall's Avatar
Cover a tall stepladder with a moving blanket between it and H2. With very little space between ladder and H2. Make sure that the ladder is against a wall on its other side so it can not fall over. Or strap it to the H2.
Then you can crawl up on a high rung and reach over half the roof. That is how I do it. I wash and wax it yearly. And remove any goo, touch up paint the seam caulk, etc.
Helps if you have long arms This is not a job for short people without scaffolding.
Old Feb 9, 2023 | 09:17 PM
Vax1op369's Avatar
I climb on top of the rear tire then on to the roof. King of the world
Old Feb 9, 2023 | 10:49 PM
finall's Avatar
If you actually did that, you would dent your roof. Unless you are 10 years old…..
Old Feb 10, 2023 | 10:08 AM
Thats a good solution to have a wall. Thats what ill do. Might try and get a 6ft pole with a mop or something. A pressure washer doesn't cut it either, it needs scrubbed.
Old Feb 10, 2023 | 11:57 AM
i weigh 170 pounds and i climb up on the roof from the hood area to clean the pine sap just don't be an idiot. spread your weight onto the rails.
Old Feb 10, 2023 | 04:44 PM
dontheo55
Mar 28, 2017 04:14 PM
gh0st
Jun 28, 2016 01:40 AM
dare8601
Nov 14, 2011 09:14 PM
SD90
Sep 16, 2009 01:40 AM
TonyH3
Mar 10, 2008 09:49 PM
