This Might Be A Boring Thread Or Poll
Old Mar 12, 2025 | 04:50 PM
Mark R's Avatar
Default This Might Be A Boring Thread Or Poll
How many of you still have roof leaks in your H2? No matter what year.
Mine still leaks even after doing all the stuff you're supposed to do. Things from this Board and YouTube and other forums. Sometimes after a rain it will be dry next to the driver side "A" pillar..than another time it will feel damp in the headliner corner.
I was told at one time it's either a bad Pinch weld or, pull the roof rail tracks out. Neither were done. So I hate to to death... But I just got to wondering who still has a leaky H2 because they haven't pulled the roof tracks to check...That's Me.
Sorry if I opened a wound and dragged this old topic out.
Old Mar 13, 2025 | 04:49 AM
RobertDez's Avatar
A couple months ago I found dampness under the a pillar, and that sponge under the carpeting soaked it up pretty good. Nothing on the headliner showing. Did the marker lights, and door seals. What finally stopped it was under the driver side large marker light, there's a small bolt that secures down the roof rack rail. Pulled it out, used Teflon tape, reinstalled. It's been dry all winter.
Old Mar 13, 2025 | 07:43 AM
calif phil's Avatar
Mine is 100% leak free, only because it stays indoors all the time. Wish you the best with your leak free journey.
Old Mar 13, 2025 | 10:51 AM
Mark R's Avatar
One spot is where that Rubber round large Gromeant in the lower "A" pillar feeds the wiring thru from the door. When That leaks you'll have water under the HUMMER logo on the door sill on the driver side where all the wiring runs to the rear. Sometimes it will be on the driver side floor. Every now and them I snap that plastic trim plate with the HUMMER logo off and check in there. Got me some grease on those hold down clips so it pops out easy.
I think mine Is coming from the roof rack rail. I'll have to suck it up and do it this summer. I have 4 Roof Rack Bars on the roof in those tracks. They are a PITA to take off to get the Roof Rial up and sealed.
Mark R's Avatar
Cheater...LMAO....
Old Mar 13, 2025 | 11:12 AM
zenith's Avatar
I've done it all as well, still leaks at both sides of the grab handles. The only solution for me is to take out the headliner, which is a PITA, and time consuming and see if I can identify the leaks from inside.
To bad GM never stepped up on this issue for at least a diagnosis from their engineers.
Old Mar 13, 2025 | 11:31 AM
Mark R's Avatar
Yep, it's still intriguing to hear that some hummers are still leaking. Mine only leaks on the driver side grab handle headliner. And as yo say.. Pulling the headliner down is a good way to locate the leak. If you can't get from outside.....Try the inside....More work. Only problem is ...it's my daily driver.
And...it's a Major job to pull it down without damaging the parts trim around the liner ....and of course... Yah got's the SIde Airbags that you have to be carefull with.
But I still Love my Leaky 2009 HUMMER H2 LUX... Known as "FATBOY"
Old Mar 13, 2025 | 12:08 PM
zenith's Avatar
I don't have to worry about the side airbags, mines an 07. But not damaging the damn visors is a problem.
Old Mar 14, 2025 | 05:59 PM
H2x2's Avatar
My 2003 still does sometimes, found windshield was seeping in, pulled headliner down just in front corner and the antenna was loose (the nut that tightens antenna to roof from inside), got new windshield, tightened antenna bolt put new weathstrip on door now right side is dry, left side headliner getting damp ordered door weatherstrip for that, might have to pull headliner down in that corner to look at antenna on the left (have 2 antennas) hope this helps someone
Old Mar 14, 2025 | 07:04 PM
Mark R's Avatar
Didn't know there is a Bolt under that large Marker Lamp Lens. I have the Marker light seal gacked up with RTV. So what you are saying is that if I pull the Marker Lamp housing and gasket up that I will be able to see a bolt to tighten down.
That kind of makes sense as the water channel on the roof runs under that Marker Lamp... Yes/ No?
