Love/Hate Relationship With Electronics
Old Nov 3, 2025 | 09:18 PM
Did you check battery resting voltage?
The battery is a storage tank & the alternator is a power plant!
Old Nov 4, 2025 | 09:28 AM
when i first got my H2 i noticed that my blinkers would stop blinking and just stay on left or right did not matter on a really cold day. it was the relay in the turnsignal module had arthritis it would bind up on cold days. a whack would get it going again but its location under the dash is awkward to get at it for a good whacking.
Old Nov 4, 2025 | 10:06 AM
Mark R's Avatar
Yep the battery is the storage tank... But when the Alternator is pumping out 14.5 volts at the battery terminal ...that's 14.5 volts to juice the entire electrical system.
So no fade at at 45 MPH on any electrical system unless its Farked up. When I tap tap on the **** and the full brilliance comes back it ain't the battery.
Old Nov 4, 2025 | 06:45 PM
Alternator Voltage Output vs AMPERE Output.
"Tap to restore"?
I would expose & clean connector/contacts TO RESTORE!:
Old Nov 5, 2025 | 10:43 AM
Mark R's Avatar
"Tap to restore"?
CRC is a Copy of this... I've been using this professionally in the Pro Audio Electronic repair industry for years. Besides... Battery Contacts and terminals were cleaned about two months ago as I added a Mice Deterrent device in the Vette and the H2. Deoxid-D5 was used on both. No conductivity problems all Lights are bright and all electrical functions working as designed....Except once in a blue moon a few taps on the 4WD switch. There is definitely a cold solder joint for the L.E.D. Power..
Old Nov 7, 2025 | 06:41 PM
https://www.youtube.com/watch?v=-45cRXX6eJI
There's a TSB from GM I posted years ago that shows warranty returned control switches investigated was due to fluid intrusion from various spills fluids liquid air fresheners leaking into the switch and after cleaning restored working perfectly.
Old Nov 7, 2025 | 08:13 PM
Mark R's Avatar
Thanks...Very Good Info. I also should report that after a tapping and rotating the switch and excessing all functions of the 4WD Hi & Low as well as Pumping up the AIr ride and dropping it back to normal ride height that the 2 is working normal and providing me with great sadistfaction as I run the Brick down the interstate.
tothemax
Nov 6, 2025 12:53 PM
Mcpousnret
Oct 28, 2013 04:36 PM
arnjoh09
Aug 12, 2013 03:04 PM
ukpaul
Oct 11, 2011 08:35 AM
VegasGuy
Apr 19, 2010 04:24 PM
