Lift?
Old May 16, 2022 | 03:58 PM
flashinq's Avatar
Default Lift?
Just got 37s on (first pic) and want it lifted like the 2nd pic, pretty sure it’s a 3” lift and was wondering what’s the best way to go about that? Keys?
Old May 16, 2022 | 04:03 PM
flashinq's Avatar
Also didn’t do anything with shocks so should I also get some shocks for them as well?
Old May 17, 2022 | 10:10 AM
If you crank the keys (using reindexed keys) enough to get 3 inches in the front you will have a few issues. One is it will ride like garbage, literally hard as a rock. Second is your ball joints and some other front end components will be destroyed in sort order. You will also need shock extenders or longer travel shocks. Max to not have it ride terrible cranking torsion keys is right about 2 inches. Still will wear components out much faster too unless you replace the UCA's with ones that have angle adjustable ball joints.
Rear depends on if it is coil spring or air suspension.
That second pic looks more like a 6 inch lift which is only done with a full on lift kit.
Steven Eric Lambert
Oct 8, 2020 12:57 PM
Watcher13
Apr 29, 2019 06:05 PM
Anthony Chiarello
Aug 24, 2014 10:25 AM
jntfj80
Jun 23, 2013 10:55 AM
Medic_Morgan
Oct 4, 2011 07:07 PM
