inside temp air sensor hummer h2 exact location
There are 2 small vent openings above the drivers door up by the roof. The rear one is the sensor, the front one is the microphone for the phone.
Changed mine last year. had to remove the lf door pillar cover..pull the inserts in the handle out and it will pull off, and the left side pillar cover behind the drivers seat and in front of the passenger set. that one has a cover that you remove with a flat screwdriver and one Phillips screw holding it in. then pull the rubber seal off the door jamb and the left side of the headliner will come down enough for u to get a hand in there and pop the sensor out.
humtheworld
12-07-2007 08:49 PM
skeeet
11-30-2006 02:19 PM
