inside temp air sensor hummer h2 exact location
Old Nov 13, 2013 | 07:57 PM
ash's Avatar
ash
Cool inside temp air sensor hummer h2 exact location
Can anyone tell me where the exact location of the inside air sensor for climate control is located and how to remove it. Thanks
Old Nov 13, 2013 | 08:39 PM
fyr145's Avatar
There are 2 small vent openings above the drivers door up by the roof. The rear one is the sensor, the front one is the microphone for the phone.
Old Nov 14, 2013 | 02:04 AM
LoJac963's Avatar
FYR is correct. For removal try slowly pulling down on it, should just be clipped into the headliner.
Old Nov 14, 2013 | 03:18 PM
H2CANEPADESIGN's Avatar
Changed mine last year. had to remove the lf door pillar cover..pull the inserts in the handle out and it will pull off, and the left side pillar cover behind the drivers seat and in front of the passenger set. that one has a cover that you remove with a flat screwdriver and one Phillips screw holding it in. then pull the rubber seal off the door jamb and the left side of the headliner will come down enough for u to get a hand in there and pop the sensor out.
31sonic
Feb 8, 2012 10:16 PM
bogy
35
Jul 21, 2009 03:05 PM
maverick1354
Aug 26, 2008 10:06 PM
humtheworld
Dec 7, 2007 08:49 PM
skeeet
Nov 30, 2006 02:19 PM
