inside temp air sensor hummer h2 exact location
Can anyone tell me where the exact location of the inside air sensor for climate control is located and how to remove it. Thanks
Originally Posted by ash
(Post 304474)
FYR is correct. For removal try slowly pulling down on it, should just be clipped into the headliner.
Changed mine last year. had to remove the lf door pillar cover..pull the inserts in the handle out and it will pull off, and the left side pillar cover behind the drivers seat and in front of the passenger set. that one has a cover that you remove with a flat screwdriver and one Phillips screw holding it in. then pull the rubber seal off the door jamb and the left side of the headliner will come down enough for u to get a hand in there and pop the sensor out.
