Hummer H2 idle surging
Old Oct 6, 2019 | 07:23 PM
  #21
Sam!'s Avatar
How many miles did you drive? Seafoam injector cleaner in the tank is a slow process.
Use only top tier gas
and seafoam could correct.
Or you could replace the fuel injectors
(8pack for $57.98)
i just did the seafoam 2cans in one tank and not much change my miss/stumble is at 1000+rpm, have removed injectors to check screens and clean and still not much change. So have you tried these injectors i was planning on sending mine in to test and cleaning shop just so i could keep the OEM but at that price might have to try them.
Old Oct 6, 2019 | 07:43 PM
  #22
myrddin's Avatar
I haven’t ordered the injectors yet. How hard are they to replace? Also how do I know it’s not the intake gasket?
i have already put the TPS on... I will try to remove it and if it’s clean I’ll take it back. I wish I had some codes to help me diagnose. If the injectors are not to bad to do I’ll order them too.
Old Oct 6, 2019 | 07:49 PM
  #23
Keep your oem injectors! Try the set to see if that corrects the issue. Replace them all, then you can go back and test the oem injectors if you have the equipment.
Old Oct 6, 2019 | 08:02 PM
  #24
3rd method:
Old Oct 6, 2019 | 08:27 PM
  #25
myrddin's Avatar
With the OEM injectors being so expensive would it make sense to just clean them vs replace with cheaper ones? I see some YouTube videos showing people rigging up a rubber hose and using carb cleaner spray with a 12 volt battery (tapping to pulse the spray through the injector till clean).
worth it or no?
Old Oct 6, 2019 | 08:56 PM
  #26
Sam!'s Avatar
worth it or no?
I tried with mine with no noticeable improvement; they are super easy to remove, 57.dlls and swap would be the best solution. Or yeah like I mentioned sending them out to get tested and cleaned to keep them OEM is also a very good idea
  #27
worth it or no?
Yes, however if you find 1 or 2, maybe more that will not spray properly after cleaning, then what?
Old Oct 6, 2019 | 09:11 PM
  #28
myrddin's Avatar
I see this tool... might get them clean... assuming the output is ok...
beler Universal Auto Car Fuel Injector Nozzle Flush Cleaner Adapter DIY Cleaning Tool Kit Set
Amazon Amazon
Old Oct 6, 2019 | 09:14 PM
  #29
myrddin's Avatar
I guess the thing that caught my attention was the price. Stock injector set was like 800.00... and the set posted was 57.00... should I expect them to be equal in quality?
Old Oct 6, 2019 | 09:27 PM
  #30
Cheaper and better chance to correct your issue than throwing a tps at it.
Like most parts limited manufactures, with many private labels.
fuel injector
