Hummer H2 HID Headlights
Old Jul 9, 2020 | 03:18 PM
  #41
The black plastic part is not an old headlight. That is the bucket - the black plastic part visible around the edges of the headlights from the front - it also goes behind them some as shown.... Still not cutting the hood in any way though.
Old Jul 9, 2020 | 10:09 PM
  #42
fastNYsix's Avatar
Do I need to disassemble and sandwich the led between the front face and rear bucket?
Old Jul 10, 2020 | 12:23 PM
  #43
It does get sandwiched.... at the top in that pic you can see one of the small torx screws that you need to remove to get the entire back half off.
Old Jul 11, 2020 | 03:42 PM
  #44
julijulez24's Avatar
what are we using to cut the plastic out? a dremel or something ?
Old Jul 11, 2020 | 07:01 PM
  #45
That is what I used...... an oscillating saw or a jigsaw would also work. Maybe even a hacksaw blade wrapped in tape in a pinch.
Old Jul 11, 2020 | 08:29 PM
  #46
WhDaFk's Avatar
I used a set of sheetmetal snips. Worked perfectly.
Old Jul 11, 2020 | 08:45 PM
  #47
I prefer/use my reciprocating saw for my cut through projects.
Old Jul 11, 2020 | 10:11 PM
  #48
Talking
https://www.youtube.com/watch?v=I0kiUnpIQF4
thank you all! will send pics soon.
Old Jul 14, 2020 | 10:19 AM
  #49
Originally Posted by NW94Z
Here you go. It was a pain splicing the new LED headlight DRL's into the factory DRL's but very doable. For the record anyone doing this you want to splice into the blue wire on the factory DRL's on an 08 H2 to run the LED DRL's. I also blacked out the grill while I was at it today. I'll get some shots at night with the low and high beams on later.
Next mod: LED bulb for the factory DRL's. Anyone want to recommend a replacement. I'd like to match the new headlight color range. I don't care if the DRL's cast light. I just want them bright enough to match the new DRL's in the headlights.
I'm also going to do the jumper mod in the fuse box to keep the DRL's on when the headlights kick on.
hey where did you get your headlights?
Old Jul 14, 2020 | 10:55 AM
  #50
Hey, you mind pointing me in the right direction of where you obtained your headlights pictured.
