Hummer H2 2006 AC warm air 15C from vents
Old Today | 04:33 AM
Mutasim's Avatar
Default Hummer H2 2006 AC warm air 15C from vents
Hi guys,
I've few issue with AC in Hummer H2 2006
1- it's showing 3 codes B3770, B0414, B0424
2- when I press air recycling switch the AC compressor clutch engaging even though the snowflake switch is off!. I've tried different relay but still same
3- AC air temperature coming from all vents is 15C (59F).
4- when changing cooling temperature it doesn't change when it's set at 15C (59F) or 32C (89.6F) the air coming out from vents it's same 15C (59F).
I've changed compressor, condenser, drier, orifice tube and refrigerant filled properly no leaking found along with cleaning evaporator.
What could be the problem?
mcaseyredman
Jun 19, 2025 01:57 PM
Munaf1
Jul 19, 2023 03:11 PM
Eurynomestolas
Jul 5, 2020 08:36 PM
jsbihn
May 7, 2015 08:01 AM
HummerGuy
Mar 17, 2007 06:37 PM
