Ac not working unless moving
Old Jul 4, 2020 | 06:23 PM
Eurynomestolas's Avatar
Default Ac not working unless moving
So I don’t know if this has something to do with the new thermostat I know they run hotter. As long as I am driving it kicks the cold air out but if I am going through a drive through it’s just like hot air. Is this a common issue? 07 h3 adventure
Old Jul 4, 2020 | 06:35 PM
Not here, post the A/C pressure gauge readings.
Old Jul 5, 2020 | 05:03 PM
The compressor is turning on and off constantly
Compressor on ac full blast
Compressor off when the ac is running
Old Jul 5, 2020 | 05:09 PM
Your low side is way to HIGH. What is the high side reading?
Old Jul 5, 2020 | 05:14 PM
I don’t have a gage for the high side unfortunately.
Old Jul 5, 2020 | 05:27 PM
bureau13's Avatar
When vehicle speed makes a difference like that, it can often be the fan clutch. Now, I'm not sure about the fans in these vehicles specifically, but that is often the case generally with belt-driven fans.
Old Jul 5, 2020 | 05:31 PM
DIY set here--->ac manifold gauge set
Btw, when you have a manifold gauge set, you don't need a $60 a/c pro, 1 time use!
12oz cans alone are under 10bucks each, and recharge(yellow hose) with the manifold gauge set.
Old Jul 5, 2020 | 05:55 PM
@hummerz sense you mentioned my low was way to high I went on YouTube and watched a video and let the low refrigerant out until it was in the 40 range seems to be working!!! Here is the video
Old Jul 5, 2020 | 05:57 PM
just replaced the fan clutch and waterpump. You didn’t even know the fan clutch wasn’t working. Now I hear the thing actually when I am driving. Totally different sound. My old fan clutch would still spin the fan but you wouldn’t know it wasn’t working.
Old Jul 5, 2020 | 08:36 PM
bureau13's Avatar
Yeah, visually they will still spin. The way they work is as it gets hotter, the clutch allows the fan to slip less, so the fan will push more air through the radiator (well, PULL more air, technically) as it gets hotter, but usually even a bad one will spin the fan enough to make it look like it's working.
jsbihn
Jun 16, 2015 08:58 AM
jsbihn
May 7, 2015 08:01 AM
rwavers
Jul 18, 2012 04:13 AM
Thorsz
Sep 15, 2010 08:09 AM
HummerGuy
Mar 17, 2007 06:37 PM
