Hub replacement question
Old Aug 10, 2020 | 02:39 PM
LoJac963's Avatar
I replaced mine and you have to replace the nut as well, they are one time use. Part number for the O-ring I believe is 15017464. Nut is 11609826.
Old Aug 10, 2020 | 02:41 PM
rpelich's Avatar
thx! yeah i orderded 2 nuts, not sure what to do about the missing o ring on my one side
ill fit the o ring on the driver side when i get to replacing the hub this weekend but i dont really want to go back and reinstall a o ring on the opposite side
Old Aug 10, 2020 | 07:00 PM
The O-ring is a safety feature for those that neglect their ride(I've never used them). Protects the grease from the wheel bearing when overheated, DUE TO WORN OUT BEARING/AND OR BRAKES BINDING/OVERHEATING, causing the the grease, to turn into a liquid, from getting onto the brake rotor, causing a potential brake failure.
Old Aug 11, 2020 | 09:04 AM
RoH2's Avatar
Originally Posted by rpelich
oh wow, heres a pic does this ring a bell?
im not very techy but i believe it sits in the steering knuckle where the hub meets when you install it.
heres a link and a pic
https://dmaxstore.com/products/?rout...spindle+o+ring
https://www.rockauto.com/en/parts/ac...b+o-ring,12808
maybe keep an eye out for this?
thx
thanks! I really had no idea....o-ring must be buried super stuck to the inside of the knuckle.
i replaced the drivers side last night and still couldn’t find it.
now I know
Old Aug 11, 2020 | 09:06 AM
RoH2's Avatar
just curious here....your statement in parenthesis.....are you saying you have never changed out o-rings when replacing hubs?
wongsol
16
May 10, 2019 07:52 AM
tharber
Mar 28, 2014 09:27 AM
redneckhoosier
Nov 30, 2013 04:49 PM
CharlieDeltaJuliet
Sep 5, 2013 04:12 PM
ultraclassic01
Oct 4, 2012 10:25 AM
