how do I move an H2 with a dead battery?
Old Feb 21, 2022 | 08:35 AM
calif phil's Avatar
You also could have crawled under the passenger side front and hooked some jumper cables or battery charger leads directly to the battery cable on the starter and the chassis ground.
Old Sep 17, 2023 | 04:38 PM
H2&M109A3Owner's Avatar
ah great idea one time my battery died cause i left the subs on and had a remote only and locked my keys in the car . they ruined my paint trying to break in and now have 3500 dollar repair bill
Old Sep 17, 2023 | 05:12 PM
"3500 dollar repair bill"? I've opened many locked outs with a wire coat hanger & some with a slim jim.
Where is the $3,500.00 damage?
Old Sep 18, 2023 | 10:57 AM
HandsomeSteve's Avatar
crawl under the H2 at driver door dissconnect the trans. shift linkage then shift on trans. backward 2 clicks. does the battery drain regularly?
Old Sep 18, 2023 | 07:11 PM
oceanbrave's Avatar
Another option:-
There is a direct path from the driver's side wheel through to the hood latch, using a pole with a bent rod, such as a modified paint roller you can release the hood and charge the battery (there is a YT video)
only possible if you have access the front left, tricky yes, cheap yes, but no damage.
Old Sep 24, 2023 | 02:09 AM
Its in the door jam I have custom paint and pinstriping you cant use slim JIM ON AN H2 they tried to use a AIR bag AND JAMED PLASTIC WEDGE in the door where it tore the paint to the metal . So they now have to match both doors and remove all the customs striping . Mine my was a diplomat humv the windows are much thicker bulletproof
juicebox123
Sep 25, 2023 12:57 PM
Tech5
Mar 17, 2011 10:32 AM
kurtdeetz
Feb 24, 2010 07:30 PM
doyleh3
Apr 2, 2008 10:01 PM
skeeet
Oct 18, 2006 12:51 AM
