URGENT: key locked in the ignition with a dead battery?
Old Feb 27, 2019 | 10:42 PM
juicebox123's Avatar
Default URGENT: key locked in the ignition with a dead battery?
I'm out of state until June for work. My friend is watching my h3. She went to start it and nothing. Key is stuck in the ignition. I have looked through threads but no real answers. If I can't get her to figure this out... I'll have a key there until June or have to spend $900 flying out to figure out something to do. Battery is 1.5 years old. I never had this happen. I should have disconnected the battery while I was gone not have her start it up every week. Lesson learned. But will charging the battery be better or worse? Does anyone have a concrete solution? Steering wheel isn't locked. It's not that wait 10 min and it'll start thing either. The battery is dead.
Old Feb 27, 2019 | 11:38 PM
happythree's Avatar
not too clear?, but if my batt was dead , id charge it,start the car and take a long ride. then drive it routinely.
Old Feb 28, 2019 | 03:48 AM
Default Um
Not sure if it's actually dead. My h3 likes to play dead sometimes... the key can't be removed from the ignition. The alarm still works. :/
Old Feb 28, 2019 | 08:30 AM
choochmalooch's Avatar
Cool
A dead battery will lock the key in the ignition. Also, even with a new fully charged battery you need to run your Hummer every 7-10 days or the battery will go dead. It's a known problem. I have installed a battery cut out switch in mine so when I go away on vacation I can cut the battery out and keep it from going dead while I'm away. Frequently I go away on business travel for 2-3 weeks at a time and after returning to my Hummer in the airport parking lot and finding the battery dead on two occasions I installed the cut out switch. Fast, easy fix.
I'd have her charge it up, start it and run it a bit, then park it and remove the positive battery terminal for now.
Old Feb 28, 2019 | 10:02 AM
Might help if you understood what a "dead battery" is. Not like a fuel tank where half full is good. You need 12.3-12.6 volts to run it, 12.0 volts is DEAD, useless. Might get a light to come on, dash to illuminate, but dead as a doorknob.
If you jump it, the key can be removed, if you have an old school 12 volt charger/booster it can be removed.
Charge you battery, and keep it charged with a battery tender plus........ best little chargers you can find, and they maintenance float in storage.
Old Feb 28, 2019 | 12:14 PM
happythree's Avatar
negative cable huh...
Old Mar 1, 2019 | 06:33 AM
Cool
My cut out is on the positive. Works just fine.
Old Sep 24, 2023 | 02:15 AM
H2&M109A3Owner's Avatar
Ah It was my fault the battery died I never had any problem with the 10 days But ill keep it in mind thank you .
Old Sep 24, 2023 | 01:22 PM
Happy Hummer's Avatar
Who keeps pulling up all these fossils?
Old Sep 25, 2023 | 12:57 PM
Archeologist = H2&M109A3Owner. READ: Old Threads/'Necro-Bumping'
bonanza
Sep 24, 2023 02:09 AM
madmayo
Jul 18, 2015 04:17 PM
HERHMR
16
Dec 26, 2012 11:11 AM
kurtdeetz
Feb 24, 2010 07:30 PM
doyleh3
Apr 2, 2008 10:01 PM
