Hood lock release cable
Old Jul 6, 2024 | 05:40 PM
Craig85's Avatar
Default Hood lock release cable
Hi All,
I’m looking for the 15066360 hood lock release cable. Is there any alternative gm cable that could be the same as the above? Maybe for the Tahoe?
Old Jul 8, 2024 | 08:34 PM
Mark R's Avatar
Originally Posted by Craig85
Hi All,
Found this with your PN search. Could be a run around,,??
http://oemcats.com/oem-parts/15066360.html
Old Jul 12, 2024 | 04:58 AM
RobertDez's Avatar
Default Hood latch cable and such
There's several postings regarding broken cables or latch assemblies and the headache involved in getting the hood open. There really is not a need for an interior hood release, unless you live in an area or someone is likely to steal your battery. With the Tilt front end, just like the over the road semi trucks, the two rubber latches on the sides are all you need. I simply took the two bolts out that the latch assembly hooks on too on the inside of the hood and left everything in place to avoid the inevitable. Plan on keeping it forever, but if I was ever to sell I can just put the two bolts in that metal loop back in in 30 seconds.
Old Jul 12, 2024 | 06:37 AM
Craig85's Avatar
I totally agree with you. It was used without the release cable for years. Now, I need to prepare my truck for a periodic review, where it’s mandatory to have. I give up to find an official one and make it by myself for bucks. I just need to know the length of it. This is that I’m looking for today
Old Jul 12, 2024 | 09:46 AM
maybe a brake cable for the rear brake of a tandem bicycle is long enough? if your making your own that is. they can be from 300cm to 400cm long.
Old Jul 12, 2024 | 03:42 PM
Craig85's Avatar
After a quick research it seems the solution is easier. I can buy a cable housing, a cable and endings. The whole solution can be $10. Of course I need to work on it, but not too much.
blharty
Apr 16, 2021 11:48 AM
docrnc
Jun 2, 2020 09:12 AM
Big Tuna
Mar 1, 2012 07:28 PM
user 0013769729713
Oct 12, 2010 02:04 PM
Gods Gift
Jan 23, 2010 08:46 AM
