HELP diagnose cranking issue
Old Oct 7, 2023 | 02:24 PM
XLRH2's Avatar
Default HELP diagnose cranking issue
delete
Old Oct 7, 2023 | 06:59 PM
H2-SUT's Avatar
possible bad ignition switch or security issue
Old Oct 8, 2023 | 07:46 AM
legerwn's Avatar
what year is your truck
Old Oct 8, 2023 | 06:48 PM
XLRH2's Avatar
Not a security issue tech 2 says ok,
If the ignition switch is the issue is that what sends signal to relay in underhood fuse panel?
I have jumped the underhood relay and no crank, this doesnt eliminate ignition switch but problem appears downstream.
from point of underhood relay to solenoid on starter, happen to know the path/wiring?
Old Oct 8, 2023 | 06:57 PM
XLRH2's Avatar
its an 03
Old Oct 10, 2023 | 08:20 PM
XLRH2's Avatar
Decided to stop wasting time searching for issue, Its getting cold in canada, lol.
Added a 40amp relay to trigger starter solenoid, through a hidden momentary button only powered when key in on position (still using factory key, ignition system and passlock system).
Bonus antitheft system!
Solved the issue with parts I had on hand and up and running in 30mins
esfop319
Dec 3, 2019 03:53 PM
Jeremy Jay Cee Crawford
Jul 30, 2018 10:13 AM
KING TANK
Nov 9, 2017 09:19 AM
djslickrick
Nov 10, 2011 09:21 AM
Pauldy
Sep 14, 2010 09:48 AM
