Stuck ignition key
Old Nov 27, 2019 | 11:39 PM
esfop319's Avatar
Default Stuck ignition key
Here is one that I've been scratching my head at...... I put the key in the ignition of my 2007 H3...Turned the key and started it. I realized that I had forgotten something in the house and turned the H3 off, but it wouldn't turn all the way to the off position. I restarted to H3 and turned it off again, but I still wasn't to turn it to the off position. After the third time of starting it and shutting it was I able to turn it all the way off and pull the key out. Hasn't happened since. Was it just a fluke or is it something more? Thanks in advance.
Old Nov 28, 2019 | 02:47 PM
Post, a pic of your battery, and battery resting voltage.
Old Dec 1, 2019 | 05:55 PM
WR3NCHE4D's Avatar
There is a solenoid attached to the key tumbler. It's designed so that you don't remove the key with the transmission in gear and will release when in park. I removed my solenoid because I'm the sole driver of the vehicle. No sticky key. I also checked that my vehicle was going into park with an expensive scan tool.
Old Dec 2, 2019 | 02:12 PM
Why are you yelling with all that BOLD print font? Why?
Left it in gear/partially in gear didn't ya?
Old Dec 2, 2019 | 05:52 PM
650Hawk's Avatar
Could also have been a slightly low battery. That will "lock" the key in the ignition. Might have had just enough juice to start, and after the third time, just enough additional surface charge from the alternator to remove the key?
Old Dec 2, 2019 | 06:17 PM
You got it! I'm disappointed that Doc didn't mention "crappy battery terminals".
Old Dec 3, 2019 | 08:00 AM
Originally Posted by doc olds
i have posted that the first mod to do to every h3 & h3t is to replace the crappy azzed pos oem battery terminals with a quality aftermarket set, like stingers or your favorite brand...... Probably near 100 times. If you google "h3 hummer battery terminals" one of the first images to come up is my truck battery with stingers installed. I was not kidding. Every one of them will fail. Only a matter of time.
Always do the easy stuff first, before you waste time to chase down electrical gremlins. It may not turn out to be your problem, but it is a necessary mod none the less.
Old Dec 3, 2019 | 10:43 AM
I got you guys learned, now for the rest of them.
Old Dec 3, 2019 | 12:12 PM
Lol
Old Dec 3, 2019 | 03:53 PM
Jeremy Jay Cee Crawford
Jul 30, 2018 10:13 AM
stoneman
May 7, 2018 01:41 PM
hummerhonduras
42
Sep 19, 2012 11:49 AM
djslickrick
Nov 10, 2011 09:21 AM
dmachine007
Sep 15, 2011 08:50 PM
