Heater motor resistor part #
Old Feb 24, 2026 | 11:36 PM
TeeStu's Avatar
Default Heater motor resistor part #
Does anybodt have the part number for the heater blower resistor.2005 H2. If the Delco is not available, whats a goog quality replace. I saw one You Tube on one the plug had to be soildered on replacement. alike to find a good quaility pulg n play if not oem.
Old Feb 25, 2026 | 12:59 PM
Chrmer3's Avatar
Amazon Amazon
That one works- MAKE SURE no water is entering from the intake under the shroud - the gasket around that intake plate WILL be shot. Water/Moisture WILL take out that resistor when it comes into the fresh air intake under that shroud.
Just a heads up
Blower Motor Resistor Heater Fan Control Module Compatible with Hummer H2 2003-2007 Replace 19331830 19329838 89023355 93803637 88986529 15-80388 15-80655 15-80911 19331830 3GSH-19E624-CA
Old Feb 25, 2026 | 01:36 PM
TeeStu's Avatar
Thanks Chrmer...
coffeydp
Nov 8, 2021 11:16 AM
oceanbrave
Sep 29, 2018 02:50 PM
MrAndrew
Oct 19, 2015 04:21 PM
BirdEye
Jan 12, 2011 10:06 AM
