Hassel ordering parts for a Hummer H2
Old Sep 25, 2023 | 10:26 AM
HandsomeSteve's Avatar
Default Hassel ordering parts for a Hummer H2
Hassel ordering GM parts for a Hummer H2 which is basically a chevy 2500 truck
I forsee another hassle just ordering parts so ppl don't understand this is a GM vehicle.
Want to replace the left front wheel speed sensor. I've been informed the wires are too thin to splice back together an will send fake infor to the ECU.
This seller says it doesn’t fit.
I believe it doe’s fit. dam
Should I just tell them it’s a chevy 2500 silverado?
https://www.ebay.com/itm/38359184584...&segname=11051
Old Sep 25, 2023 | 02:02 PM
did you confirm the GM part numbers? are they the same? if so order for the 2500. compare the connectors as well incase they differ.
Old Sep 25, 2023 | 03:28 PM
I can’t go by part #s w/ ebay bc it’s a no brand name knock off from a foreign country.
https://www.ebay.com/itm/383591845847
well actuely they refer to there parts as Brand universeparts which everyone knows is counterfeited ebay is fine w/ but theve sold over 160 so it must be a decent knock off.
sure doe’s look like the rock autohttps://www.rockauto.com/en/moreinfo.php?pk=6699608&cc=1434194&pt=1912&jsn=365 attached RA SS thanks
my electroic 4x4 shifting isn't working I think it's bc of the wheel speed sensors wire is cut.
edit:
think I'll splice this wire like it's only 2 inside the sheath.
I have a 07saab 97x 5.3i same crape differnt day it's even worst at amazome.
Old Sep 26, 2023 | 04:03 PM
Gavin Costigan's Avatar
I thought the same thing with part numbers for brake lines. 06-07 have the same part numbers on rock auto but what showed up was two completely different parts.
In case you need to know 08 2500 4wd silverados and 08 hummer h2s do have the same brake lines at least in the front.
Old Sep 27, 2023 | 08:05 AM
dontheo55's Avatar
Just a thought about eBay Hummer parts. I have had so many problems with eBay items not fitting properly I have started to purchase parts from Amazon. Pricing is usually about the same but if it doesn’t fit you just send it back and look again for the correct part on Amazon. I just went through the same thing with a tractor and my boat. One can also find that a part will be there the next day or too. Just an observation.
Old Sep 28, 2023 | 08:15 PM
they are different. the H2 ones are stitched into the leather and the leather mounting points velcro / clips to the seat frame /cushion positions are different. but you can overlook that if you wish. i believe the electrical connector is the same then just sandwich them in and hope they stay in place with loose leather.or get creative.
Old Oct 1, 2023 | 03:10 PM
finall's Avatar
You have to cut the old ones off the leather skins. Then you have to use 3M spray glue on the new ones. You can not just slip them in. Or they will move around and get damaged.
There is a reason they are sewn onto the seat skin.
The suppliers should have installation videos which show you that….
Old Oct 1, 2023 | 07:15 PM
Mark R's Avatar
I never trust the part numbers that are listed on different sites. To make sure I get the correct parts I call a GM Dealer parts department and give them the VIN #. There are always changes in Mfg dates and years. Happened to day. I have a Intermittent "Crankshaft Positioning Sensor". Went on the web and looked around and found 3 different part numbers. Call my local Chevy dealer and He gave me the correct number and had it in stock, Genuine GM made in America.
Of course I paid more but who GAS.
clsimmon
Jul 17, 2018 06:26 PM
2014b
May 15, 2013 11:25 AM
oohank
Mar 22, 2013 06:29 PM
Mcpousnret
Mar 22, 2013 12:04 PM
BIGT2148
Nov 27, 2009 08:50 PM
