H2 DRL Enclosures
Old Jul 3, 2019 | 02:47 PM
H2-SUT's Avatar
Here are 2 possibilities off ebay, first one is from a Tacoma, 2nd is from a Tundra, I think the back part of the reflector would be a problem.
05-11 Tacoma
Tundra
Old Jul 3, 2019 | 03:27 PM
LoJac963's Avatar
You can easily buy round LED lights on amazon for cheap which fill the hole plenty. Silicone the hell out of them since cheap lights will leak eventually. There are round LEDs on amazon with 4 mounting bosses on the back. Some threaded rod, a few washers and nuts and bam you have new LED DRLs without making brackets, templates, yadda yadda. I've done it for local owners years ago. My current set have been going strong for 4 years without issue.
These are the lights I use:
https://www.amazon.com/gp/product/B00JR23P6I/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00JR23P6I/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Grind off the mounting boss and rattle can it black then do the threaded rods on the back through the factory holes. No hacking up the mounts or anything.
Old Jul 12, 2019 | 10:46 PM
H2-SUT's Avatar
Originally Posted by legerwn
https://www.hummerforums.com/forum/h...l-today-40358/
This was my fix for the DRL's on my 08, like yours the reflective material was in very bad shape and looked terrible
Neal
Hey Neal,
They look really good, the only thing is where did you get them?
Old Jul 13, 2019 | 02:59 PM
legerwn's Avatar
Old Jul 19, 2019 | 09:46 PM
H2-SUT's Avatar
Thanks, they were sold out but I found the same product on another site. I received them yesterday and they really look like a nice match to the headlight. I plan on building a backing plate on my metal lathe and installing them. Hopefully the finished product will look as good as your.
Dan
Old Jul 20, 2019 | 08:20 AM
legerwn's Avatar
Keep us updated on your progress,
Neal
Old Jul 22, 2019 | 10:55 AM
H2-SUT's Avatar
Hey Neal,
The project moves ahead, I have scrapped the idea of using billet aluminum and used your approach of going with wood. I do have a couple of questions. I have included 2 pictures, the first is the rear of the block that mounts towards the bumper. You can see where I routed it out to allow the bulb to be installed and rotate. Unfortunately there is not enough room in install the connector to the bulb. My second picture is the finished spacer. I painted it with truck bed liner in an attempt to protect it from water.
Short of modifying the tabs on the bulb so I could plug it in or going to an LED or HID that plugs straight in I don't see any solution. I also took a close look at your final installation and it appears you installed a foam gasket to take up the extra space since the assembly sticks out further then the original.
I was wondering if you ever consider or tried the aftermarket metal bezels that go around the opening?
Thanks, Dan
Old Jul 22, 2019 | 11:02 AM
I dont think he actually left the wood in there. I believe he just made that to use as a template to drill the plastic in the bumper to mount the new lights is all. That is likely also why you are having problems getting the plug to connect.
Old Jul 22, 2019 | 11:44 AM
H2-SUT's Avatar
Your probably right, but even if you did drill into the plastic bumper and mount them directly it looks as though the plug will still interfere with the lower stud that holds the lamp assembly in. I was looking at an LED replacement for an H10 bulb and it does not have an angled connector so that could work.
You know, looking at it again your right, if the wood donut was not used the only thing holding in the new light would be the three mounting point clips, the old mounting stud would not be used and that would allow for the full rotation and connection. But with that said I really didn't want to drill any extra holes in the plastic bumper. So, either I use the donut and put in a different bulb or drill the bumper, Humm,
Old Jul 22, 2019 | 12:17 PM
Even if you drill the bumper, it can still be put back to stock if someone really wanted to. The stock lights would still hide the additional holes.
