grabbing sensation on drivetrain
Old Feb 10, 2022 | 06:12 PM
yellabummer's Avatar
Default grabbing sensation on drivetrain
anybody else has this problem, it feels like brakes grabbing but i just replaced rotors, calipers and pads a couple months ago. i bled properly, they've been fine. what else could cause this? no noises that i can hear, just a constant grabbing feeling that is very noticeable.
Old Feb 10, 2022 | 07:01 PM
Among the many causes of grabbing brakes are contaminated brake pads (dust, grease, fluid), misaligned calipers, loose brake mounting bolts, seized caliper pistons and/or sliding pins and damaged brake lines or rubber hoses.
Old Feb 11, 2022 | 02:52 PM
i dont think its the brakes, i replaced fluid, calipers, rotors and pads. now tho, im thinking it could be the alignment causing this issue
Old Feb 11, 2022 | 03:23 PM
Alignment? Simple check, lift wheels off the ground and spin them.
Old Apr 1, 2022 | 09:50 AM
Gavin Costigan's Avatar
Is this in a straight line or only when the wheel is turned? This actually happened a little while ago on the forum and it turns out the guy forgot he left the transfer case in 4hi lock, so be sure it's not something stupidly simple like that first.
It could also be the hydroboost unit. Though I'm not terrible qualified to offer advice on that.
Old Apr 1, 2022 | 01:34 PM
its only after ive been driving a while. now the rpms drop, and it almost stalls out on me, and it also occasionally will just turn over on the first crank. yea its not locked in 4 wheel drive. i get no codes, ive checked the cats, they're fine according to the o2 sensors, ive also checked coils, and injectors, the spark plugs look good and are the correct ones. the symptoms mimmicks a vacuum leak or lack of fuel....but like i said, its only about an hour into driving it i get these symptoms... but no check engine light or faults.
motley1987
23
May 8, 2014 09:09 AM
JOJ220
23
Jun 15, 2011 08:07 AM
drtom
Nov 21, 2010 12:33 PM
H3driver
Sep 30, 2010 12:53 PM
boomer
May 5, 2008 08:22 AM
