grabbing sensation on drivetrain
anybody else has this problem, it feels like brakes grabbing but i just replaced rotors, calipers and pads a couple months ago. i bled properly, they've been fine. what else could cause this? no noises that i can hear, just a constant grabbing feeling that is very noticeable.
Among the many causes of grabbing brakes are contaminated brake pads (dust, grease, fluid), misaligned calipers, loose brake mounting bolts, seized caliper pistons and/or sliding pins and damaged brake lines or rubber hoses.
(Post 391710)
Alignment? Simple check, lift wheels off the ground and spin them.
Originally Posted by yellabummer
(Post 391708)
It could also be the hydroboost unit. Though I'm not terrible qualified to offer advice on that. |
Originally Posted by Gavin Costigan
(Post 392811)
Is this in a straight line or only when the wheel is turned? This actually happened a little while ago on the forum and it turns out the guy forgot he left the transfer case in 4hi lock, so be sure it's not something stupidly simple like that first.
