Fog lights replacement
Old Jun 16, 2024 | 06:05 PM
Craig85's Avatar
Default Fog lights replacement
Hi All,
I have a H2 (2003). I have to replace the fog lights. Which other brand’s fog lights can be used in H2 (like GMC Yukon or maybe Wrangler)?
The new fog lights should be halogen and should have European conformity that makes it difficult. Can you suggest me something?
Old Jun 24, 2024 | 11:08 AM
RobertDez's Avatar
Default They're actually daytime running lights
And check my post for the specifics.
https://www.hummerforums.com/forum/h...upgrade-48174/
Old Jun 24, 2024 | 01:41 PM
Craig85's Avatar
Thank you! You are great!
Old Jun 26, 2024 | 05:10 AM
ethan12's Avatar
Replacing fog lights on a vehicle is a straightforward task, but the exact process can vary depending on the make and model of your car.
Old Jun 26, 2024 | 10:26 PM
finall's Avatar
Just replace the bulbs, not the housing , with LED. Sylvania Zevo. Takes five minutes. Ditto for the headlights. Keep your stock housings and save a ton of money.
Old Jun 27, 2024 | 02:33 AM
Craig85's Avatar
I agree, that would be the best. However, in my country I have to comply the rules (even if I don’t agree with them). For that I have to use halogens and they should have european confirmity sign (E signs). As I don’t find OEM H2 lights with E signs, I try to find some other model that has the same size of lights (maybe Chevy Tahoe? or something). But I don’t know which other car has the same size.
Old Jun 27, 2024 | 12:08 PM
finall's Avatar
What archaic country in the world does not allow used of LED headlights? North Korea? I do not believe it.
1/3 of the cars in the world now run on LED headlights from the factory. And the rest will in a few years. It is so much more efficient, run cooler, and provide whiter light.
Incandescent and Halogens are being phased out. Halogens are now 64-year old technology.
And how would anybody find out what bulb you have in your headlights? Are they going to rip your car apart?
Old Jun 27, 2024 | 04:53 PM
Craig85's Avatar
yep, I agree with you. Here in Hungary, the government doesn’t allow anything on the car (including carparts) if it’s not OEM. Of course it’s important on the periodic investigation only, not necessary on the road. It means I will use the halogens just for the investigation and will obtain a led for the roads.
However, somehow I need to solve it.
Old Jun 27, 2024 | 06:49 PM
BLK WLF's Avatar
and you have thoe clowns that put ****ty china leds in and the blind jalf of the world that come at them 🤬
Don't get me wrong though, a lit of led units are good but if you modify a vehicle from 2003 to 2009 on the H2 do it right, spend the money on some good units and have them DOT tested.
Afi42678
Apr 27, 2023 12:33 PM
ski.dive
May 12, 2019 12:15 PM
AnomH3
Mar 26, 2011 01:21 PM
jasoncox05
Jul 29, 2010 05:12 PM
Bennersj
Dec 15, 2007 09:54 PM
