Electrical problems. Radio, gauges, and windows won’t work while on
Old Jan 22, 2020 | 07:04 PM
Originally Posted by xxbigjohn79xx
Also I noticed that the dimmer lights seem to go on and off on their own and somewhat seem
to
completely stay on
What aftermarket accessories have been installed?
Old Jan 22, 2020 | 07:27 PM
xxbigjohn79xx's Avatar
nothing besides an aftermarket radio last year
Old Jan 22, 2020 | 07:37 PM
Any signs of water intrusion? You should eliminate those lights for now before you ruin the battery.
Old Jan 22, 2020 | 07:50 PM
yes actually there has been a water leak I haven’t been able to track for a while, front driver side floor
Old Jan 22, 2020 | 08:03 PM
Water is not good for connections and modules! Stop the leak, dry it out, and clean the connections and bcm. In the meantime eliminate any battery draw, and check all fuses.
Old Jan 23, 2020 | 07:13 AM
Agreed - the BCM (body control module) is basically up against the firewall behind the left dash vent, light switch, etc. NOT easy to remove/replace and you do not want water getting into it. I still suspect it could be the ignition cylinder switch or a ground problem. Could be one of the grounds in the dash, down by the kick panel, under the drivers door against the frame, etc.
Old Feb 6, 2023 | 06:12 PM
BooYde's Avatar
Default Did you every figure out the electrical problem? I’m having the same issue.
They just turned off at once all of a sudden. While engine cranked they will not turn on, if you just turn the key forward one notch to engage they will be functional but once I turn the car on they completely shut off and the battery and ABS light turn on. I’ve heard that the h2 has common electrical problems just wondering if any of y’all have encountered this and what did you did to fix the problem . Thanks in advance ! John
Old Feb 7, 2023 | 11:45 AM
Gavin Costigan's Avatar
Inspect and test the wiring going from the door to the car. It seems possible there may be an issue there as well as with the door switches themselves on the door. Probably worth a check since they sometimes get wet and are known to go bad, and because the windows work from the back.
bluebow
Feb 22, 2021 10:39 AM
Rockandroll00
Oct 11, 2014 11:47 AM
giant H2
May 24, 2014 07:35 AM
trxblack
Jan 14, 2014 02:39 PM
Ghost Rider
Aug 22, 2012 02:43 PM
